show me your modified fuel rail covers!
looking for pics of modified fuel rail covers, i want to hack up these vette covers as little as possible to fit my camaro. thanks
Here you go. Drivers side doesn't need much. There are a couple brackets that attach under the fuel rail bolts that hold cables. I had to trim for them. When I took my intake off I didnt reinstall them.
Passenger side I trimmed off about the back 1/3.
OK after looking at your engine bay you shouldn't need to cut your Drivers side at all. As for the Passenger side you will have to cut a hole for the dip stick and take a little chunck out of the back more then i did for this big wire loom that goes back there and then finally you will have to cut for you throttle cable. You wont have to take out as much as i did for the throttle cable tho since you only have one cable not too like me bc i don't have traction control. It really not that hard tho to test fit and cut and test fit and cut thats how i did it. Here are some pics i circled where you need to cut.
Here are some installed pics after i got them cut and before paint.
OK after looking at your engine bay you shouldn't need to cut your passenger side at all. As for the drivers side you will have to cut a hole for the dip stick and take a little chunck out of the back more then i did for this big wire loom that goes back there and then finally you will have to cut for you throttle cable. You wont have to take out as much as i did for the throttle cable tho since you only have one cable not too like me bc i don't have traction control. It really not that hard tho to test fit and cut and test fit and cut thats how i did it. Here are some pics i circled where you need to cut.
I used a product called Evercoat Poly-Flex. It works great on plastics bc it will flex and not crack. It worked really good we had some where i work so i just borrowed some
yea. im going to leave it like this for week so i can see how it is with heat and everything. i might add some heat tape to the bottom of them. and im still not sure what to do, im thinking black with pewter writing
lol ya i always tell girls i have a corvette engine
WOW!! LOOKS GREAT!,
the red lettering really pops w/ the blk n pewter
but I've also seen a stainless strip that covers the CORVETT lettering that
has SS in blk.........looks good now though!
