Smoothed Valve Covers++
Here are mine finished!
I left the rearest tab on because i was going to mount my relo kit there but i have changed my mind, i am going to mount it under the whiper cowl. Installed pics on car will come when i put the motor back in the car.
All steps were tack ragged and waited on flash times.
Thanks, Pheonix
Primer
After sanding the primer with 400grt and spraying it red where Trans Am decals go.
Black base sprayed over the entire piece.
Peeling off the decals to expose the red letters.
After peeling.
Finished product after two coats of clear.
Thanks, Pheonix
Primer
After peeling.
Thanks! I dont have a write up. I did not take pics from the beggining when i was cutting the tabs and sanding them down. If i do another set i will most defenately do a write up. If you need some help with yours you can PM me at any time.
