Sponsored by: DashLynx
Trans Am HID converstion
Old 04-11-2009, 10:09 PM
inahrtbt's Avatar
Default Trans Am HID converstion
Hey guys...
Has anyone done a T/A HID conversion? If so where is the BEST place to locate the parts?? Thank You..
Old 04-11-2009, 10:25 PM
JuStIn_Ws6's Avatar
Ummmm
Old 04-11-2009, 10:34 PM
zach_ws6's Avatar
I got mine from carhidkits.com
so far, so good.
do some searching around though.
Old 04-11-2009, 10:43 PM
98 WS6's Avatar
https://ls1tech.com/forums/appearanc...-trans-am.html
Old 04-12-2009, 12:13 AM
bobbyd's Avatar
this is the one that I followed and am very happy with the results
Old 04-12-2009, 01:58 AM
Copy & Paste Moderator
VIP1's Avatar
Here is a good primer I've posted a few times:
Originally Posted by VIP1
Here is a primer...
HID = High Intensity Discharge
Its a bulb and ballast assembly. Instead of a filament glowing in a glass tube (incandescent & halogen), HID is a arc of electricity at a high voltage in a glass tube.
Projector Housing
Its a light housing with a reflector "bowl" in the rear, cut-off shield in the middle, and curved glass focus in front. It produces a wide even light pattern with a sharp flat or stepped line with light below and little to no light above. Some projectors are halogen, some are HID.
Reflector Housing
Standard incandescent & Halogen housing with a reflector in the rear and either Clear or Fresnel or Parabolic glass in front. The cut-off and general pattern is not as well defined as a projector. There is no cut-off shield. The beam pattern is determined by the glass pattern and reflector shape. Almost all reflector housings are halogen or incandescent. Only a couple HID reflector setups were available from the OEMs.
Check out the Lighting FAQ for some more info on Headlight upgrades and projectors. HID Planet's Forums is also a great place for information.
You shouldn't install HID in the High Beam location because they can't be flashed quickly. You'd loose the ability to signal other drivers with the high beams. Vehicles that come from the factory with HID high beam have Bi-Xenon projectors. Its one projector housing for low beam and high beam with a movable cut-off shield. For the high beam, the cut-off shield rises to let more light upwards like a standard high beam pattern.
Here are some examples of bare projectors:
(Not my hand.)
Here is an example of a projector beam pattern:
(My 2001 Formula with Hella 90mm H9 projector, modified cut-off, and 4300K HID kit.)
(tadpole's Miata with FX35 projectors)
(Please note that those pics were not taken at the same place or settings so you can't compare brightness. That being said, the FX projectors are brighter, wider, and have better spread than the Hella 90mm.)
Here is some good reading:
http://www.danielsternlighting.com/t...nversions.html
http://www.danielsternlighting.com/t...e/bad/bad.html
http://www.danielsternlighting.com/t...good/good.html
Some good discussion here:
https://ls1tech.com/forums/appearanc...un-around.html
Regarding HID Kits:
Basically Halogen and HID produce light differently (glowing filament vs. arc of light) and HID kits don't always place the arc in the same place as the Halogen filament. And some halogen filaments are horizontal to the glass tube. All HID arcs are vertical in the glass tube. Which means that the focal point will be off and you'll get a bad light pattern. Also, HID puts out a lot more light than Halogen. Therefore a Halogen Reflector Housing intended to spread a certain amount of light of a certain shape over a certain area now has a lot more light going outside this area not necessarily where it is needed and often where it shouldn't be (high, blotchy, and often into the eyes of others).
This problem becomes compounded with dual filament hi/lo applications. I've seen four kinds of so-called "bi-xenon" HID kits designed for dual filament applications:
1.) One fixed/non-movable HID capsule
You lose high beam but its position and resulting pattern is like the high beams are stuck on and you are blinding everyone.
2.) One HID capsule for low beam and One Halogen bulb for high beam attached to same base
Neither is positioned correctly and the high beam bulb is not replicable. Sucks for you if it blows.
3.) Two HID capsules on one base. Neither is positioned correctly and you have way too much light coming out for high beam and you can't flash-to-pass because HID starts up slowly and you can damage the bulbs and ballasts from frequent flashing.
4.) One Movable HID capsule often with a built-in shield/cap. This is the "best" of these options because it tries to put the arc in close to the correct position for high/low operation. The capsule will move depending on whether you have the high or low beam activated. The beam pattern is still not good, but not as bad as the above options.
For clarification, a bi-xenon projector has only one fixed/non-movable HID bulb. When high beam is activated, the cut-off shield inside the projector moves to allow more light higher through the lens.
Check out the Lighting FAQ: https://ls1tech.com/forums/showthread.php?t=710357
The K number is the color temp. It is not the brightness (well not directly, I'll explain). 4000K - 5000K is the brightest. Continuing up the color scale, the light gets bluer then purpler and the lumen output (the actual measurement of light) decreases. In other words, a 10000K HID kit is dimmer than a 4300K HID kit. Our eyes are least sensitive to blue light. Blue light also scatters more easily. In the end, we can see better with 4300K HID for many reasons.
For the 1993-1997 Firebird, you'd need a bi-xenon setup otherwise you'd lose high beams.
Check out the Lighting FAQ for more info on lighting modifications/improvements (HID and Halogen).
Old 04-12-2009, 06:59 AM
98 WS6's Avatar
Thanks bobbyd,
VIP, is that you with the tattoos?
Old 04-12-2009, 07:04 AM
inahrtbt's Avatar
THANK YOU guys !!!! The info is great and very helpful.. B T W.. AWESOME F-Body's..
Old 04-12-2009, 08:00 AM
VIP1's Avatar
No. I don't know who's hand that is.
Old 04-12-2009, 09:06 AM
DarknessHunter's Avatar
sweet was looking for this info
Old 04-12-2009, 11:58 PM
Detoxx03's Avatar
I just ordered the bulbs now I need to figure out what eurolamp conversion kit to get and this i'll use the write up above for assistance.
Old 04-24-2009, 01:18 AM
Detoxx03's Avatar
Another vote for this write-up. Damn I love hid's
Old 04-24-2009, 02:10 PM
bobbyd's Avatar
did you get yours already? if so lets see some pics man
Old 04-24-2009, 10:29 PM
Detoxx03's Avatar
As requested
[IMG][/IMG]
[IMG][/IMG]
Old 07-11-2009, 04:48 AM
LCplmarine98's Avatar
Damn Detoxx that looks sick. Cant wait to do mine and another vote for the writeup great info.
Old 07-14-2009, 03:08 PM
Trans-Am Terrorist's Avatar
Totally used this one and it was a piece of cake... Thanks 98 WS6
Old 07-14-2009, 04:11 PM
99Ls1fever's Avatar
Nice info guys!!!
Old 07-14-2009, 06:36 PM
Detoxx03's Avatar
Hey thanks man
Old 07-15-2009, 06:32 AM
No Juice's Avatar
Detoxx - what did you do for your fogs? I've heard of people having problems them melting the housings?
Old 07-15-2009, 05:28 PM
This is one during a cloudy day... I will try to get some better ones so you can get the idea... As for the fogs melting... I just dont drive with them on as much... Other than that I dont know what to tell you
Quick Reply: Trans Am HID converstion
