ws6 hood on formula?
Alright, I just got a ws6 hood on my formula. I got it painted white and the metal stuff where the nose is, also got hit white. Instead of painting it black, i was thinking about just removing that material for more air flow. Would that be a bad idea? I think it would look way better too...
you mean where the ram air should be? yeah you can cut it out, but make sure it will be ok structurally because i've seen an aftermarket hood that look like it would break around the hoodlatch if it was cut. call the manufacturer i'm sure they can tell you
Yes.. It has grills..
I'd be iffy to cut them out, just because of the look and what not, if not only the structure..
Look at emblempros.com and see if you can get one of their overlays to fit over the grills.. They make a polished piece as well as other acrylics.
