brake fluid on headlights????
ok i need some of yalls advice... so my dad is really good friends with this mechanic, he is a great guy and def knows some tricks to make things work... well yesterday my dad was washing his 00 maxima and his headlights were HORRIBLE! they were yellow and hayzzy, well my dads mechanic told him to rub the headlights down with some breake fluid and it'll clean them right up... so i told him i wouldnt count my lucky stars on it working... sure enough it cleaned them up... they weren't wet sanding perfect but they were about 85% clear and could just use some polishing... although it did leave the light kinda sticky, does anyone know any kinda specifics on brake fluid and headlights that could give me some insight if this is bad for you headlights or not... i would put up some pics but i have not before pics of his headlights because i mean it's his DD...
Another little trick is using Armor-all wipes. Same kind of idea. You're filling in the microabrasions on the surface and thats why you get a "smooth looking" surface....because it is smooth (meaning level)....plus, you're "polishing" the lenses too. But it maybe lasts a week or so. But you get like 25 wipes in a bottle.
You can get a 3m kit from wal-mart that has a round pad that goes into a drill and then it has all the sanding pads all the way up to a buffing pad with buffing compound. Its like $20 or so but it works great, i used it on mine.
I would never put brake fluid near my car, unless it was going in the reservoir.
Use a piece of sand paper and a buffer with some compound. It will actually last, and look nice.
If you dont have a buffer, get a kit from walmart and use their wheel in a drill.
Glycol Ethers are pretty strong solvents, used for thinning paint and much more.
What you're doing by putting the brake fluid on plastic is dissolving the outer most layer of plastic it will look level and even more clear. But you are really damaging the plastic. The tacky feeling you are getting is dissolved plastic, it will either harden back up after the solvents evaporate or worse, dissolve right through the lens. If I were you I would wash the headlights off with soap and water to neutralize the solvent and prevent the brake fluid from dissolving the entire lens.
