Hid bulb for stock firebird
Guys I wanted to know what is the hid bulb size for our stock wiring. Basically i want to open up the stock housings and insert hid bulbs, but I want use the stock wiring to the ballast. Thanks
You would need to get a sealed beam conversion kit such as eurolights. But I highly recommend getting projectors such as the BLS kit.
https://ls1tech.com/forums/appearanc...-retro-gp.html
I know but I do not have the money for either but I do have to bad headlights I just wanted the bulb size like 9006, what is the correct size for a bird
Just UP GRADE SAVE MONEY !
Go to http://www.eurolamps.com/eurolamps/c...headlights.htm
& buy the conversion kit to make your headlights go from sealed to the newer style bulb. Then buy the bulbs from the website I showed you ^. This way you can simply plug in the bulb into the new housing supplied by euro lamps and makes the install much easier.
http://www.ddtuning.com/index.php?p=...=102&parent=85
For the Headlights ^ the bulb # is H7 and for the Fog Lights series 880
My frd (Ws6Kid) used 55w 8k headlights, & 35w 6k Fog lights
ya just do the conversion from eurolamps...honestly its the best way 2 go if you dont have 500 to do the badass BLS kit i wish i had the money to do that but i jut ordered my kit from euro lamps n im waitin for it to come in n intall it
I had the eurolights "conversion kits"
Go to www.eurolamps.com/eurolamps/camaro_headlights.htm
& buy the conversion kit to make your headlights go from sealed to the newer style bulb. This way you can simply plug in the bulb into the new housing supplied by euro lamps and makes the install much easier.
www.ddtuning.com/index.php?p=product&id=102&parent=85
Check out post # 731... Better quality then Eurolamps and last time I checked cheaper!!
https://ls1tech.com/forums/pontiac-f...l#post13145552
^Oh yea the housing looks alot better! I'm leaning towards LMC now!!
Can I use the LMC housing to go with the ddmtuning??
