Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
#361
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Thank You,
Ray
Although, if the motor is not tight using the tabs, it will probably strip the gears again. Then you'll have to replace the gear.
#363
I replaced one of my gears with a new plastic one and it stripped pretty quickly. I'm done fixing them. Done, done, done. ![Soapbox](https://ls1tech.com/forums/images/smilies2/soapbox.gif)
I'm not driving the car much right now so this is my temp fix. Believe it or not, these Pilot driving lights are better than the stock units.
Soon to be this style once I get some money together to build the projectors how I want them.
![Name: IMG_8447b.jpg
Size: 46.4 KB](https://ls1tech.com/forums/attachments/pontiac-firebird-1967-2002/623040d1501364174-firebird-headlights-all-comments-questions-regarding-headlights-go-here-img_8447b.jpg)
![Name: Custonheadlightdesign1.jpg
Size: 28.2 KB](https://ls1tech.com/forums/attachments/pontiac-firebird-1967-2002/623041d1501364174-firebird-headlights-all-comments-questions-regarding-headlights-go-here-custonheadlightdesign1.jpg)
#364
Not sure if anyone replied..... I didn't read all 19 pages (OMG!!!!)
Anyway.... you can drill a hole where the tab broke off and stick a bold and nut through it. Make sure the nut is the same diameter as the tab that broke off.
#365
Hey guys...ive had LOADS of headlight problems outta my 99 TA---BUT! (i didnt go back to see if someone said this already) Any local Oreilly store should now carry reman headlight motors! i picked mine up for about 60 bux and they have a LIFETIME WARRANTY!
If u want to switch out your gears u can too, they made the case halfs screw together instead of glue, so u could put in brass gears, or just leave the plastic ones in it til they break and warranty it...hopefully i didnt repost but i think they just recently started carrying those things.
#372
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
#373
#374
I would just raise them and pull the fuses. Then order it online and see if it can be shipped to you.
#376
![Name: gpi.jpg
Size: 31.7 KB](https://ls1tech.com/forums/attachments/pontiac-firebird-1967-2002/623026d1501364149-firebird-headlights-all-comments-questions-regarding-headlights-go-here-gpi.jpg)
![](http://img.photobucket.com/albums/v335/JasonWW/Misc%209/gpim.jpg)
#380
I looked online. It shows they are $65.99 with a $15 core charge for the right side and a $25 core for the left side. The pics don't show the screw-on cover, though. They come from CARDONE INDUSTRIES.
