Since its an LS car, here's a quick correction and detail of my TA
Very awesome work man! Not sure why pewter is not more popular I for one love the color looks fantastic when cleaned up.
What did you use for the inside of the wheels? Mine are in the same boat packed dirty of 10 years of dirty and crap.
Thanks, I used Sonax to break it up a bit then a brillo pad and some soap/water + and elbow grease. I then took a old yellow compounding pad and some high cut compound to make it a little better. But in all honesty it need to be sanded and repolished the right way. I just wanted to clean it up for now.
I used the Porter cable and menzerna 203 on a 3" orange (med cut) pad to start. Took a couple of passes at it and worked some spots for quite some time. Then I went over it with the rest of the car on a final pass with menzerna 106fa and a white (light cut) pad.
I use a similar approach to headlight correction but often start with an aggressive pad and/or compound if they are real bad. I'll take my time with it instead of trying to wetsand.
