Sponsored by: DashLynx
Does Any 1 Know How ToO...??
Old 06-08-2011, 06:07 PM
09camarossls2's Avatar
Default Does Any 1 Know How ToO...??
Exterior Door Window Sill (guide) (Plastic)...??
Does AnyBody Know How To Remove & INSTALL This Back..? I've had Bad experience on my Last Camaro tryN to remove it.. And Wasent able to leave it back how it fitted B 4 i messed with it.. It seems once You remove it.. it wont fit Nice And Tight again.. Pops-Out.. THANX..!
Attachment 300131
Old 06-08-2011, 07:32 PM
ssteven's Avatar
My driver side was loose also. I squeezed the clips a bit and tightend it up. You'll see the clips once the door panel is off.
Old 06-08-2011, 07:35 PM
ANTICOP RAM AIR's Avatar
those clips are made to dig in and not come out, chances are the are rusted or brittle.. you can try to slide a piece of stainless metal like roof flashing or something like that up in between the clip and the door, that worked for me but dont get your hopes up, they dont like being removed... just try not to rip a groove in the door. Thats what makes them not fit tight next time..
Old 06-08-2011, 11:11 PM
Raptor_WS6's Avatar
yeah, after my car got painted the shop put them back on and it doesnt stay
Old 06-08-2011, 11:13 PM
AwsmGy's Avatar
Just bend the clips a little bit.
Old 06-09-2011, 12:06 AM
Thanx Guys.. I'll Give it a try.. I Have to do it.. Or else i have red under it..!!
Old 06-09-2011, 01:34 AM
Raptor_WS6's Avatar
the painter didnt remove it when he painted it? thats gay, have him fix it
Old 06-09-2011, 02:00 PM
No he didnt.. he is gonna fix it.. and the rest of the other ****-ups he did.. i didnt think he would for the price of the labor he did-it for
Old 06-09-2011, 06:20 PM
crazyelf's Avatar
To remove it, start at the side near the handle and start tugging on it carefully moving further up as it starts coming out. If you keep tugging to far away from the next clip then the leverage will bend it. Its almost impossible not to bend the last 8 inches or so unless you completely remove the triangle bracket that holds the mirror(pain to line back up after removed)
Thats how I did it, Mine sits perfect against the door and window still. When installing it back I did have to tweak the clips and even slightly bend it straight again.
Just be very patient with it and you will be ok
Old 06-18-2011, 02:38 AM
Thanx I Will Do..!!
Quick Reply: Does Any 1 Know How ToO...??
