Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird How to Clean Foggy Headlights<br>Step by step instructions for do-it-yourself repairs.
How to clean up my headlights? They're cloudy.
My car has been sitting for quite a while. The headlights are the factory 1998 lights that came with it. I was planning on opening them up and doing the Whistler Mod to them, but the plastic is pretty cloudy and nasty.
What do you recommend to clean up the plastic? I've been told to sand the inside and outside and I've been told to use Plast-X.
I own Plast-X, but experience has taught me that it can take forever to buff out just some slight fading/cloudiness, and mine are pretty bad.
Has anyone sanded the inside and outside of their headlight lenses and had it come out nice?
I know I could buy new headlights, but right now the (very small) budget is going towards other things. I'd really like to be able to salvage what I've got.
Any help you guys can give me would be appreciated.
To clean them up will be a lot of buffing and sanding so if you don't want to do that then just buy another set. Basically what you are going to do is wetsand them down to get all the "crazing" out on the outside. Once you have that done you will have most likely taken off the UV protectant on the lenses so I would suggest clear coating them. This will protect the plastic from being scratched any more from the little particles of dust and such in the air when you drive. Also you can buff them and everything when you do the car since it is paint.
The inside shouldn't be cloudy. It should just be the outside due to them being exposed to the elements. It may look like the inside is clouding from the outside but it shouldn't be.
What would you recommend using for the clearcoat exactly? Just rattle can paint? Or something special?
Wet sanding using one of the kits is a good solution when the lenses are really bad, but you can accomplish the same results on lenses that are pretty far gone with a DA and a cutting pad.
This was done with a DA, a Meg's 7007 pad and Meg's 105
i've used the mother headlamp restore kit and it works. but when i used it on my camaro it kinda cleaned them up but not completely. i would try the kit and if that doesnt work the get new head light, which is what im doing,
That's quite a difference. It's amazing what a little time and effort can do.
1 Post
All I did with mine was wet sand and clear coated them and keep some wax on the head lights and that's been over a year ago I think and they look about the same as when I first did them.
I tried Plast-x first on mine. It helped, but they were still foggy. Next I tried the 3M kit that uses a power drill as a buffer. That helped more, but wasn't enough on its own. So then I used leftover plast-x with the 3M pad. It looked pretty good so I used some sealer and called it a day. Then they started fogging up again, so I wetsanded them with 800, 1000, 1500, 2000, and 2500 wet/dry paper and followed up with Plast-x and the sealer. Looked great, but not perfect.
Then I started liking the whistler look and said "f*%k it" and bought new whistler depo lights
Internet Mechanic
Pretty much what anyone will say.
Do a google search for Plasti X or head light restore. I have a rotary so for me I have a great too. Many companies came out with a DIY and a elec drill which is basically the same, just cant crank it up.
On a 2003 Honda Civic Recently I put my LC Orange Pad and M105 and cranked it to 4 on my Makhita and it cleared it right up. Just need to keep it protected.
My wife's 2007 HHR has some not as clear as it was new but its taken almost 5 years to see anything. So I will do a quick clean up and keep it waxed.
If you want to do it fast... wet them, put some ***white toothpaste on a dry towel/cloth and start to rub the surface. It actualy works pretty well. Buddy told me about this and wanted to try it out for ***** and gigs before I went and bought some professional products... ended up not even going out because it worked so well. My headlights weren't horrible though. Try this DIY method and if it doesn't work... you've only wasted enough toothpaste for 1 night and you can always go get the fancy big name stuff !
It couldn't have gone much worse. It looks like I'll need all new headlights.
The lenses not only did not come clean, they got worse. I'd never seen anything like it and neither had my friend. McGuire's, Plast-X, nothing worked. So we moved onto wetsanding, and it got worse still. Buffing afterward didn't help.
They started off bad, but legal. Now they're so cloudy to the point that light doesn't pass through them.
Then the chrome on the reflectors peeled off when we taped them up for painting. They were in bad shape, but now they're useless. I'm not sure they're salvageable.
Where in Texas are you ?
