Camaro Stance - What springs are these?
So I came across this pic, and THIS is the stance I want. I realize the tires out back might be pushing the front down a tad more.
Those of you with Camaro's, if your stance is like this, what spring/shock setup are you running? Or if anybody has an idea just from looking. Thanks!
Unless you hear from the owner, it's pretty much impossible to tell by sight alone. eibach, strano, bmr, etc have similar heights when you look at most pics (with the exception of eibach sportlines), and that is not all that plays in to the equation. Rim size and tire size play a part, as the car will appear lower if the combination of rim+tire sizes yield a larger overall diameter, as they will fill more of the wheel well area, as is the case with the two sets of rims/tires I have.
Also the placement of the wheels matters to. Depending on the offset, use of spacers, etc, the more the tires are set out closer to the fender, the lower the car may look, and most likely the better the stance will look. Not necessarily flush or anything like that, just not so set back in the wheel well area. though I don't car for rims/tires sticking out past the fender, it looks out of place for the most part.
hell, the amount/type of driving you do affects them too (to an extent, even if only a little), I know my car sat higher before I really broke in my BMR springs. I love how they sit now.
another thing to consider, did the owner leave in the rear isolators or not? that makes a big difference in the rear, and lends a considerable drop when removed.
Just sayin, you can't really look at a pic and try to guess and make your buying decision off of that. At least I wouldn't call that a smart thing to do. There are more factors to consider than the springs to be able to assume you'll get the same stance as someone else. You absolutely need to consider what wheels/tires sizes/offsets are used and things like whether or not the isolators are still in.
All in all though, there are indeed many factors that need to be considered. Hopefully I'll find a few sitting on OEWheels that have the stance I'm looking for, cause that's what wheels I'd be getting. Actually gonna go pop over to the OEWheels thread, but keep the low in the front Camaro's coming!
