Sponsored by: DashLynx
Lacquer Thinner to remove VHT Nightshade from Taillights?
Old 07-24-2012, 12:46 PM
Rise of the Phoenix's Avatar
Default Lacquer Thinner to remove VHT Nightshade from Taillights?
I did a search on here and didn't come up with much. From what I've seen, it appears that lacquer thinner will take it right off, but at the same time, I don't want to mess up the taillights. Only reason I'm doing this is because my car didn't pass inspection with the smoked tails. Anyone else have better options for removing this stuff?
Old 07-24-2012, 12:52 PM
UnVMySS's Avatar
I'd use denatured alcohol. It won't destroy the lenses and will take the paint off. Plus one for removing the paint. The look gets old after a while...
Old 07-24-2012, 12:56 PM
MR_M's Avatar
I would be careful with the lacquer thinner. I used it to remove vht on a previous car once and although it took the vht off it caused some hazing on the lense. I would try wet sanding first.
Old 07-24-2012, 01:15 PM
What grit should I use? Do you think wet sanding will take it all off? I need to do this TONIGHT so I can take my car back in tomorrow to be re-inspected.
Old 07-24-2012, 01:16 PM
SparkyJJO's Avatar
If you sand enough it'll come off, yes.
Are yours totally black or just darkened a little bit?
Old 07-24-2012, 01:39 PM
Internet Mechanic
BlackScreaminMachine's Avatar
You can sand, just need to level out the plastic via buffer and compound like PlasticX
Old 07-24-2012, 01:53 PM
stevesfbody's Avatar
Yeah lacquer thinner is a no-no
Old 07-24-2012, 03:00 PM
__Z__'s Avatar
Just use gasoline... ive used it on several pairs without incident
Old 07-24-2012, 03:01 PM
So would using something like 400 grit not be a good idea? I've got that at home already. I just need a quick fix so I can take it back in tomorrow to pass inspection. I'm sure 400 grit isn't ideal, but will it work without ******* up my taillight lenses?
You just put some on a towel and wipe?
Old 07-24-2012, 03:05 PM
__Z__'s Avatar
yes, ive even poured some onto the lights, and scrub away...
Old 07-24-2012, 03:21 PM
SparkyJJO's Avatar
400 grit would take the tint off pretty quick. You would probably have some scratches in the lenses that you'd need to use finer grits to sand out and they would look dull and ugly, but they would be normal color again.
Old 07-24-2012, 03:30 PM
Wouldn't using the finer grits after going with the 400 grit keep it from looking dull and ugly? Obviously giving them a good polish after all the sanding is done will help too.
I honestly plan on re-spraying them with VHT Nightshade once I get the car passed. I'm only removing it because I have to in order to get it to pass inspection.
Old 07-24-2012, 04:29 PM
SparkyJJO's Avatar
Yeah, bad sentence structure there I meant it would look dull and ugly after the 400 grit but it should at least pass inspection I would think. Yes, the finer grits would then sand out the ugliness.
Maybe you should look to get a cheap set of tails for inspection purposes. Like buy a set that have warped lenses for dirt cheap.
Old 07-24-2012, 05:22 PM
Use 1500 and buff after
Old 07-24-2012, 06:48 PM
bayer-z28's Avatar
I wetsanded the living HELL out of mine just to lighten it up a shade. Unless you've got some arms of steel and a lot of time, it may take a while.
Old 07-24-2012, 06:55 PM
SparkyJJO's Avatar
Need a coarser grit to start with. I had an issue with unevenness and cracking the first time I used niteshades so I sanded it down and started again. Coarse grit didn't take too long to do it, and I can guarantee you I certainly don't have arms of steel Of course use a finer grit to get rid of the deeper marks before tinting again.
Old 07-24-2012, 07:31 PM
bigbomber5's Avatar
I used Goof Off, no problems
Old 07-24-2012, 08:39 PM
VinR1's Avatar
X2 for gasoline - 2min per lense tops
Old 07-24-2012, 08:53 PM
__Z__'s Avatar
+50, gonna be redoing mine soon, and this is how ill go about stripping them.
Quick Reply: Lacquer Thinner to remove VHT Nightshade from Taillights?
