Sponsored by: DashLynx
polishing headlights
Old 04-28-2004, 12:45 AM
Assassin's Avatar
Default polishing headlights
is it correct to use 2000 grit sandpaper and watersand then buff out w/ automotive plastic polish? what did u guys do?
Old 04-28-2004, 02:43 AM
faethor's Avatar
just use blue magic metal (yes, i said metal) polish before u go scratchin the **** out of it with sand paper. it works on my lightbar, it'll work on ur headlights.
Old 04-28-2004, 08:07 AM
OWENMUSTANG's Avatar
unless your lamps are like,,,yellow i would use something less aggressive.
faethor's metal polish sounds interesting, or heavy compound..
just treat them like paint, they will look great!
Old 04-28-2004, 10:49 AM
Assassin's Avatar
they are really bad, you can feel the roughness w/ your hand, but I will try some of that metal polish, I tried some mothers mag polish(just about everything I had handy), and it didnt seem to do jack... they are not yellow but just hazed all to hell
Old 04-28-2004, 01:29 PM
LS1PoweredZ28's Avatar
I used 1500 grit, and it took me forever to get the haze and scratches out. If I had to do it again, I would go with something a little more corse, then finish with 1500 or 2000 grit.
Kevin
Old 04-29-2004, 06:29 PM
floman's Avatar
I posted about two weeks ago on this exact thing. Mine were yellow and dingy looking and looked awful! I wetsanded first with 2000 grit but could'nt get it all off, so I changed to 1200 grit and it sanded much better. I then buffed them out with meguirs diamond cut compound which is some what aggresive buffing compound. The results was great, wish I had taken before and after pics to post. They dont look brand new , but the before and after difference is awsome and a whole lot cheaper than new lights from GM. Another suggestion, have a friend hold the light while you buff it, the buffer will grab the little **** and sling it!! Floyd
Old 04-29-2004, 10:33 PM
01Z0H6's Avatar
Mine look as though they have "overspray" on them!
Know that is not the case as i bought my car off the showroom floor..
I'll try the 1200 grit as well.... Thanks.
Old 04-29-2004, 10:51 PM
LS1 Sounds's Avatar
Here's what I did:
https://ls1tech.com/forums/appearance-detailing/157192-fixed-my-yellow-cracked-headlight-today-pics.html
Quick Reply: polishing headlights
