Sponsored by: DashLynx
Power Antenna
Old 05-09-2004, 01:22 PM
99PewterBone's Avatar
Default Power Antenna
I started my car today and as the antenna was extending, there was a major grinding sound. Now the antenna will not go down. Is this the whole motor or some other "portion" Help.
If its the motor, what is the part number?
Old 05-09-2004, 03:18 PM
libertine1015's Avatar
I think it comes as a whole unit. DO NOT BUY AFTERMARKET like the units for sale at RK Sport, they are crap. I bought one and to think I could have just wiped my *** with that hundred dollars and flushed it instead! oh well, maybe next time :-)
Old 05-09-2004, 05:59 PM
Copy & Paste Moderator
VIP1's Avatar
Its sounds like might be toast.
With the car off, have you tried to gently pull it up or push it down? If it eventually "catches" and goes down, then it may just need to be lubed up. Otherwise, it may be time for replacement. If the car is still under warranty, then this may be covered.
PN: 10402859
Here is a site on how to install it. The site is about how to install it in a Camaro, which didnt some with a power antenna stock, but it should still be of some help.
http://www.blackcamaro.com/antenna.htm
Old 05-09-2004, 06:04 PM
bill99hawk's Avatar
You probably just need a new antenna Mast.
Old 05-09-2004, 06:43 PM
I will open it up tonight. See what I find.
Old 05-09-2004, 08:43 PM
kulablkta's Avatar
180$ for a power antenna. i bent mine when the cover blew off and it dimpled in around the antenna to. the antenna cost 180 and having the dent pulled was another 75$ man bc of my stupiudity i had to pay 255$ man what a waste
Old 05-09-2004, 09:53 PM
Toonz's Avatar
I'd guess it was the mast that broke off, usually at the base. Mine just did this recently, I cut the plastic mast out, pushed the antenna down, and unplugged the motor. Great "apperance" mod, and the radio stations still come in fine.
Easy part to replace if you want to go that route. Only $70 at gmpartsdirect.
Quick Reply: Power Antenna
