Sponsored by: DashLynx
Wiring Mod question?
Old 05-17-2004, 11:30 AM
Z'mnypit's Avatar
Default Wiring Mod question?
Im trying to do this without cutting any wires. I have everything unpluged. My question is there are two little wires that are tan, & green.. They are still conected.. Do you have to cut these wires are do they plug in somewhere?
Old 05-17-2004, 11:33 AM
Durs98SS's Avatar
I believe they plug into the brakes somewhere. Not 100% sure because I did this mod awhile ago. Check behind the rotors...
Old 05-17-2004, 01:45 PM
Xsta Z 28's Avatar
I cut those 2. solidering two wires together, is small change compared to doing the whole harness . . .
Old 05-17-2004, 02:39 PM
slow's Avatar
they go to the abs sensor, you can undo it, and relocate, without cutting, follow it down
Ryan
Old 05-17-2004, 04:42 PM
Copy & Paste Moderator
VIP1's Avatar
Im a bit lost.... What mod is this?
Old 05-17-2004, 05:27 PM
LawmanSS's Avatar
this is the "!wire" mod...basically, you relocate the bundle of wires located atop the passenger side wheel well. The wires are rerouted through the gap between the strut tower and the inner fender liner. You can either cut the wires and reattach the ends, or drill a hole big enough to pass the connector through...do a search on "!WIRE MOD", there are a bunch of good threads explaining the process...here's a link to Steve's page...look under 2000 Camaro SS for the writeup on this mod:
http://www.z069.us/
Old 05-17-2004, 10:41 PM
VIP1's Avatar
o, yea. I know about the !wire mod. It wasnt clear that is what he is talking about because the headlights on the Camaro have tan/green/purple wires too. I wasn't sure if he was doing one of the headlight mods (fog+headlight on or Halo). I see now. Sorry I am of no help on this but at least I can give you a TTT.
Old 05-18-2004, 07:33 AM
Z'mnypit's Avatar
I completed it yesterday afternoon, Man it looks so much better.. Thanks for the help....
