2057 light bulb
no, just know when you look at the bulb from the side one "tab" is about half way up and the other tab is down toward the bottom, the later 4th gens went to the 3157 "wedge" bulbs wish solved this annoying part of bulb installs.
as for which pin is brake and which is parking, you'd have to test the socket to see which completes the circuit when turned on using a multi-meter.
