LED Strip Rear Parking Lights
I'm always trying to update the Trans Am so it doesn't look like an 18 year old car...
Previously, I updated my headlights for the BLS HID projector kit, and converted my DRL/Signal housing to switch back LED bars. Now I've converted all my interior lights to red LEDs and my rear parking lights to LED strips. I tapped into the parking lights, disabled the low signal wire to the 3157 sockets, and removed the 194 bulb. The 5050 weatherproof LED strip is attached to the bottom and edge of the tail light housing. So now when the parking lights are on, only the strip illuminates. Brake and signal remain the same. These aren't the best shots so I'll try and take some better night time shots later.
With brake/signal light.
Interior Red LEDs and cargo area strips.
I know you are not asking for opinions, I don't think you need to do anything to update the car though, yours look great as is, and I still get looks in stock form. But with that being said I think (if you are open to it) you should consider doing something like this with the leds wrapping all around the tail lights and filler panel. I know most people here don't wanna imitate the mopar crowd but I really like that styling choice by them.
This was my first try and I usually go through a few iterations before I settle on what I like. I think I need to diffuse the LEDs so you don't see the individual lights, but I haven't seen how mine look at night yet and I don't know if I want to compromise the light output. I do like the full wrap on MOPAR cars, though. I just need to figure out how to do it cleanly and still be able to remove the tail light housings when I need to.
Not that I thought it wouldn't look good but that dusk shot looks a lot better then I imagined it would. If you want more of a car shape then maybe just continue on the bottom across the filler panel, that way it wont look so abrupt when it ends.
Very cool though.
Edit: I wanted to ask also but clicked post too fast. Are the LED stripes on the outside of the housing outlining it, or are they in the space with the small gap?
Very cool though.
They're actually on the outside of the housing, but behind the lip. They are projecting into the gap between the housing and the bumper (thank goodness for giant panel gaps...). The problem with that, though, is that from the rear, you can't see the lights wrapping around the bend since the curve faces the light output to the sides. That's why the light seems to end toward the outside the the car. You can see what I mean in the third picture in the original post.
as I said in the Bird section I really like this idea. I actually wanted to do reverse honeycomb lights using a set of clear lenses from 6le, but ran out of free time. this makes me think of that project and I really like what you have done here.
In regards to more shape I wonder what it would look like if you went around the outside corners of the tail light and maybe stopped at the trunk deck? would provide more curvature to the light strip without going all the way around the tails and filler panel I personally think that look would be a bit much on a bird. Not because of it being similar to the charger, I just think it would look weird since the back of the car is rounded off as opposed to how the charger has that squareish inset area for the tails and filler that compliment the look of the light strip.
I hear ya. One of the reasons I really want to figure out to diffuse them so they look like a solid strip. EL wire was another thought but I don't know if the would be bright enough.
I couldn't figure it out before, and I normally disliked the LT1 tail lights, but that is the vibe I get from this. It's got that same grid style with the strip. The smoked lights really made it stand out. Looks really cool because its something different
isnt there a lip where the lense actually hangs over the housing for the tail lamp?
if so I cant remember if the paintwork is on the outside of the lense or not but you could see if you can remove the coloring from the lense where the lip over hangs (saddly this might ruin a set of tails though) The rougher texture would help to act as a diffuser for the red led's. something I had planned when I did my turnsignal LED's for my front bumper, but ended up not going through with as the stip had a silocone wrap on it that helped diffuse the light quite a bit.
that said you could dry these
http://www.ebay.com/itm/Red-2x-60cm-...5Xdh5e&vxp=mtr
3 years later, I finally was able to work on the tail lights. I replaced the strips with LED tubes and went full width. I like it a lot better. Any idea how to separate the turn signal from the brake signal? I'd like to incorporate a sequential turn signal into the LED tube and use the original sockets just for brakes.
Daylight
Dusk
Before
Daylight
Dusk
Before
The following users liked this post:
PhoenixPhile (08-04-2020)
