water spots on my nbm
i tried claying them off, i tried waxing them off, and i tried polishing them off. they absolutely will not come off of my car. i don't know what to do. the only thing all the other things did was scratch my car a little! i'm royally pissed off and i have no idea how to solve the problem. help!
Tuffluck...you of all people asking a question???? I thought by now you were a guru, can't believe somethings got ya stumped. You have such a beautiful car...hopefully you can get those spots out. No one on autotopia has any answers for ya? Better car care? Are you using a porter cable or just by hand?
Justin
Justin
unforgiven, thanks for the compliments. i think you'd be suprised how stumped i really am at these spots. i've tried claybarring twice, and waxed twice as well. these spots are, more than likely, permanent. autopia is not working for me. i don't have a porter cable, but i am now considering buying one and seeing if that will solve the problem. i really only have the spots on my hood, so i think if i bought a porter cable and used the DACP i have lying around, the results might impress me...or at least make me not so angry.
My trick: distilled water and white wine vinegar. Mix equal parts thoroughly in a spray bottle, then wipe off with a clean towel. I do the spots/spotty areas, not the whole car. I usually follow up with a spritz of clean water and a chamois.
-Mike
-Mike
Originally Posted by black02TA
Try a little bit of WD-40... it gets glue off fairly easy.. Just see what it'll do to the water spots... Let me know.
the white vinegar/water did not work. i'm stumped. acid rain sounds more like the key. it's not something on my paint, it's something that has stained it or tarnished it. if it were a substance, believe me, it would have been lifted by this point.
Sorry bud,
I've got a '98 with hood water spots also. Tried everything you have and the rest of the car looks brand new except the hood. I'm repainting her once we return from Italy in a couple years, then she'll stay in a garage for the most part. Something has to be up with the paint on the hoods, they're terrible. I look at all these European cars over here and the hoods are fine, but the American car hoods become jacked up over time.
Claybar, Venigar, Mr. Clean thing, washing at night, using a leaf blower, distilled water, it all did nothing to those water spots on the hood. Everywhere else on the car was good to go except for small scratches, etc.
Good luck.
Good luck.
This could help but it also could cause you paint damage if you don't know what your doing.
1. Get one of these http://www.coastaltool.com/cgi-bin/S...3aa+1092442819
2. Then this http://www.eastwoodcompany.com/shopp...sh+chip+repair
3. Water spray bottle.
Fill the spray bottle with distilled water and a few drops of car soap, using the the fingertip sanding spool with a 1500 grit disk lightly sand while spraying water over the area were the damage is. The more you sand the more clear you take off, if you go too far you'll get what is known as a split coat and you don't want that. Try a couple of strokes and then polish with the Poter Cable polisher and the 3M Finesse-it Finishing Material.
A few things:
Z5 contains no cleaning agents. It's not going to magically lift off water spots.
If cleaning wax and clay bars aren't pulling off the water spots, neither is a quick detailer.
WD-40 may work, at least give it a shot
White vinegar and distilled water, as suggested, would be another option, but since that didn't work, I think it would be worth the investment in the Porter Cable 7424. Contrary to the above, it is not likely to damage your paint since it is a "dual action" random orbital as opposed to a circular buffer. I just used mine for the first time last week and was impressed with the results.
the wd40 idea scares me just a little, heh. the hood is the only thing with the water spots on it.
the only i can think of is that the sprinklers in the apt complex sprayed on the hood, and then the next day the sun baked the water onto the hood. i'm sure some chemicals were used to purify the sprinkler water, and that's probably what stained the paint. it's only noticeable if the sun if reflecting off of it very brightly, which is good. it still pisses me the hell off.
i'll probably try the wd40, and see what that does. i'm guessing it won't do anything.
if i must resort to wetsanding (porter cable option will be first), i'll just buy another hood. that's way more trouble than it's worth.
alright, tried the wd40, it didn't do a damn thing. now that i think about it, i really doubt the PC will do anything because i think the clear is actually stained. to get the stains out, i believe wetsanding would be necessary, at which point i still couldn't say how deep the stains are. i dunno
-Mike
-Mike
