Driving lights are out
Well I think they are the driving lights the orange ones? Well when I wrecked my car the people that fixed it put a white bulb in when I needed an orange one and now my passenger side light is out how Do I get to both of them I tried but no luck? And when that passenger side light is out my right blinker dont work..?
You can get to their harnesses by reaching behind your headlight. Give it a twist to unlock it, then pull it straight out. If you can't see what's going on behind there, you can also take your headlight assembly out (it's very easy to remove).
'Bird Director
To remove the bulb for the DRL/turn signal on a Trans Am, just reach in the vent opening right below the DRL/turn signal housing. You should be able to reach up and feel the back of the housing. Just grab the back of the bulb and twist it. It should come right out. There should be just enough wiring attached to be able to pull it out into the lower vent opening so that you can easily replace the bulb. It's kind of tight squeeze for your hand, but that's the easiest way I've found to do it.
ok thanks im bout to start on it...another question..What could be the reson for my door locks not working? If I try to lock it inside they just beep? Do I have to take the door panel out or what
well I got both of them by the trap doors...easy way
But my passenger side socket had water in it and like coroded all the inside of it what would I use to clean it..i tried usin a knife but only got a little.
Also anyone know anything about the door locks?
Thanks
Thanks
Thanks
Thanks
