Washing the LT1 Engine bay?
I'd like to clean my engine and the engine bay up a little bit as the dirt and grime is really bumming it up. Anyone have any tips on how would be the best way to clean it? What products should I own before attempting it etc. etc.
hey I use the CD2 engine cleaning kit its a cleaner and a detailer. This stuff works great just make sure you have covered all major componets and of course DO NOT CRANK WITH CLOTHS ON ENGINE! Immedialtely crank for 20 min after rinsing.
I clean my engine about once every 2 weeks during the dry months. If it is really dirty, you are probably going to have to scrub some, but once you get it all cleaned up, it's easy to maintain. Go get yourself a bottle of Simple Green Automotive spray, that's what I use. Hose down the engine bay with a light spray/mist. And just avoid spraying where the optispark is!! After you have the entire engine sprayed down, take the bottle of simple green and spray down EVERYTHING with it. Now let that sit for 10-15 minutes. Come back and spray it back down with the light spray/mist on the hose. It's going to take a little bit of spraying to get all the bubles of the simple green off. If it is really dirty, use a sponge or rag to scrub the parts before you spray off the simple green. Be patient, if you let it actually sit for 10-15 minutes, the simple green works away and lifts all kinds of dirt. Also wash your engine when the engine is cold. Good luck!
