Door Molding & Trans Am Emblem removal question**
Greetings,
I read alot of posts on the door moldings (ding protector), and trans am emblem removal. So I decided to remove these.
Getting them off is fairly easy, but I was unable to remove all of the leftover adhesive.
I used a heavy duty engine cleaner. It said de-greaser, dirt removal, so I figured it would work for this. It worked decent, but there is still a little residue.
The residue that I am referring to is like a 2 millimeter tall strip that continues the length of the door. It is leftover from the bottom part of the adhesive tape. It basically looks like a small marker in the color a little darker than pewter was taken in a straight line horizontally across my door. Therefore the removal of the adhesive was probably 95% successful.
I am wondering how to get that last 5%.
I tried a razor blade, but that wasn't working well and it was removing some of the clear coat.
Any one have any ideas?
Thanks.
Thanks.
When I did this I used Adhesive Remover by Duck. That worked wll enough, but I also used something my Step father let me use but the name of it escapes me but I'll edit it in when i find out.
Goo Gone and a plastic spatula from the kitchen did it for me when removing the letters. Another trick is to soak a paper towel in Goo Gone and lay it on the area and let it soak in for 10-15 minutes. Spraying it every so often to keep the area wet while waiting. Don't use a razor, to risky.
I used Goo Gone (orange colored stuff at Lowes) and a cotton ball. Came right off.
I also had used a heat gun to heat up the emblems when removing them. That may have prepped the left over adhesive for easy removal.
