Removing haze
Removing haze
I had some scrathces in my car so I used 3M Medium Cut Rubbung compound. IT took most of the scrathes out, but now I have some hazing.
What do you recommend to continue on and then build up a deep shine...at least as deep as you can on a white car.
I'm waiting for my Porter Cable polisher to finnish up the job.
Don't all jump in at once!!
I called the Mequiars tech line and they suggest the Meguiars #83 and then wax with Mequairs NXT Generation Tech Wax...maybe a top off with #34.
This was based on only having the Porter Cable 7424 and not a Dewalt 849 to use something like #4
...any thoughts????
I had to order the #83 online so it'll be about a week until I can test it out.
...any thoughts????
Originally Posted by screamin94Z
3M Finesse It, comes in a white bottle. its not cheap but worth it.
Well I just ordered a bottle from Amazon. When I'm done I'll be able to do some side by side comparos on 3M Finesse it vs Meguiars #83 using the Porter Cable 7424.
I'd like a Dewalt 849, but I'd the more agressive rotary action might just get me troouble
nope id go 83 or 80. Thats why you are supposed to use the 3m products with a rotory cause then you wont get that hazing. Just get some DACP or SG and it should bring out the depth for you. If you dont want to wait and order that online or at a PBE store the Meguiars7 or 9 should help a bit.
www.autotopia.org is a very good place to read and learn about auto detailing. If you haven't ever been to that site I would recomend you go there and do as much reading as possible before the PC shows up.
Sounds like you need to polish the car. The PC will help a lot with this. If you can't wait for the PC I would try the #83 by hand and see what you can do. You will need to rub for a while to bring back a high gloss finish. Have fun.
The car is in good sgape, I'm just trying to get the deepest wetest look I can out of white and cover up some small scratches here and there. Nothing major, a few cats slipping off the Zaino and the normal micro scratches from towels and dirt. I did put some scratches in the hood from a contaminated bonnet, but they're not that noticable.
What do you mean by PC?
Originally Posted by ACW
PC = Porter Cable
I have the PC 7424. It works great, but won't cut like rotating wheel on say a Dewalt 849.
They must of been some serious scratched to use med cut.I'd never use more than fine cut.If it was to bad for fine cut i'd wet sand it with 1200 to 1600 grit paper.
Originally Posted by 6']['9
you really wont get any depth on white IMHO. You will get more reflections than anything.
What can I say, I'm in this forum so I'm kind of **** about the finish.
