Sponsored by: DashLynx
SOM of a B!#ch Calipers
Old 04-25-2005, 07:38 AM
No Juice's Avatar
Default SOM of a B!#ch Calipers
I finally finished these damn things. What a pain in the ***. It took me about 3 weekends to finish them. Here are the steps I took:
1) took the brackets off but left the calipers attached.
2) scrubbed both with brake cleaner and a wire brush
3) painted the brackets and rotors with Plasticoat caliper paint
4) put the brackets back on and taped off then re-attached the calipers to the brackets. Used a plastic grocery bag to cover the brackets and other things.
5) sprayed 2-3 coats of Duplicolor high temp engine enamel primer
6) sprayed 2-3 coats of SOM paint from the dealer (5oz. can)
7) sprayed 2-3 coats of Duplicolor high temp clear
They look good to me but I hope they hold up because I'm not doing that again
Attached Thumbnails SOM of a B!#ch Calipers-caliper1.jpg   SOM of a B!#ch Calipers-caliper2.jpg   SOM of a B!#ch Calipers-caliper3.jpg   SOM of a B!#ch Calipers-caliper4.jpg   SOM of a B!#ch Calipers-car4-24-05.jpg
Old 04-25-2005, 07:56 AM
JasonWW's Avatar
Looks damn good. 3 weekends, though? Ouch.
I was able to do mine in about 10 hours. A lot of the drying time was spent cleaning the brackets. Clean one, spray it. Start cleaning the next while the paint is drying, etc...
Old 04-25-2005, 08:06 AM
No Juice's Avatar
Yeah, I didn't work on them during the week but I did all the painting at once. So basically I would do the primer one weekend, color the next weekend and clear the last weekend. That High temp paint says it needs 3-5 days to cure before painting over it so thats what I did.
Old 04-25-2005, 08:33 AM
XtinctHawk02's Avatar
Nice job!
Talk about taking your time.......
Old 04-25-2005, 08:56 AM
JasonWW's Avatar
It must be enamel. You have about a 5 hour window to add layers after the first color layer is sprayed. If you put another coat on after 5 hours it will likely, wrinkle on you. After the 5 hours you have to leave it be for maybe 5-7 days to fully cure. If you use a lot of layers and only let it set for 4-5 days for instance and you add a fresh coat of color or clear, you again might get a wrinkly finish.
I didn't use primer on mine. I sprayed color, waited 20min. another coat of color, waited 20 min. and then clear/20min. and clear/20min. then put on car.
For those who need it to dry quickly, you can use the brush on G2 paints.
http://www.g2usa.com/wheel.shtml
If I redo mine, I will use this.
Old 04-25-2005, 09:34 AM
1F8TL02WS6's Avatar
I did mine in one night on my SOM. I Had to use the touch up paint cans aswell. No one wanted to sell me a can in SOM cause no one had em LOL. Bastards, but yea they look great man. EXACT same color scheme as mine too.
Old 04-25-2005, 11:15 AM
12stones's Avatar
Looks good! better to take your time and do it right then rush it and it turn out looking like crap!
Old 04-25-2005, 12:09 PM
ZR2877's Avatar
Looks good. Now just gotta keep em clean.
Old 04-25-2005, 10:51 PM
fastmatt98's Avatar
Look like mine, good job
Old 04-25-2005, 10:53 PM
fastmatt98's Avatar
Damn big pics, sorry bout that.
