Scared to install cme valance
I having been screwing with my exhaust for over a month now. I finally got the tips on and I am in the process of putting the valance on. But after researching for install tips I am scared to try. I am afraid that if I put it on it wont stay up very long. I read about the emblem adhesive but what if I decide to take it off some day. I didnt know that all that held the valance on was 3m tape. If I would have known before I bought it I wouldnt have gotten it. I mean damn I spent $150 on something that is held up with tape? I am not a engineer but I think I could have probably thought up a better way to hold this damn thing on. Sorry just needed to vent.
If you search there are a few good posts on this.
I used the tape and it is still on there. I have even pressure washed my car when washing it.
Make sure you clean the bumper with wax/grease remover and use adhesion promoter on the valance.
Good Luck
Good Luck
cant you screw it on somehow? i have the 2 piece kit from slp and it also has the 3M tape but has pre-drilled holes so you can screw them on the underside of the bumper. do you wanna trade?
Its got 3 pine cone plugs that hold it up also. 1 goes behind each wheel, & 1 goes dead center of the tips. Im the one that typed the threads about emblem adhesive. Everyone seems to think that it pulls the paint off of scars it & etc. The 3m emblem adhesive dries like plastic & peals off extremly easly. It doesnt dry like super glue or gorilla glue. Its not that stropng. Im thinking about pulling mine off when I get home & snap some pics just so everyone can see that you cant even tell it was there. This is the stuff I used:
And here are the results, These are the closest ones I have right now.
Well, I bought some emblem adhesive but I am going to give the 3m tape a try first. I think I have some adhesion promoter if not I will wait until tomorrow to get some and try it then.
I picked up some more of 3m tape b/c I read that they didnt supply enough to begin with, I took the 3m out of the package to look at it and noticed that it is thinner. It is the same width but not as thick. It does seem a lot stickyer than the stuff from slp. Should I just use the thinner stuff? Or will that be a problem?
LS1Tech Co-Founder
I installed my CME valence over the weekend without any problems. SLP provides the kit with a roll of thick tape, and a roll of thin tape. The thick tape goes on the rear section, the thin tape goes on the side sections of the valence.
Its much easier to install with two people. One to hold it in place, the other to pull the red tape backing off.
clean the tape mounting areas (on the valence and the bumper) with rubbing alcohol and a lint-free rag. Old t-shirt works well. Put the tape on the valence (thin on sides, thick on rear and corners). Peel back about an inch of the red tape at each end of the tape pieces. Fold them up so that the red tape sticks out above the top of the valence about an inch (so you can grab it).
remove the two lower push-in bumper clips. Install the CME and put those clips back in place. Get a buddy to hold the CME in position, and carefully peel those red tape ends out while holding the CME in place. When you are done, install the three 'pine tree' push-in things. Had to remove the rear wheels to drill the ones that go on the inside of the fenders. I installed my tips last, once I had my valence in place. Made it easier to make sure it was lined up correctly.
Originally Posted by Shooter_Jay
For the record, I work in engineering, and adhesives can be a great way to mount things
Call SLP and tell them to send you another mounting kit. They completely forgot mine and had to send me one seperately. BTW, here is how it looks on my hugger 99 SS:
Hey you probably dont know me by my name on here but I am the guy that sold you the lift, wheels and tires for you truck a few years ago.
I will probably just go back to the autoparts tomorrow and get the right tape. slp takes to long to ship I am eager to get mine done. I will be sure to post up some pics when I get it done hopefully saturday.
Ok I got it on, it holds a lot better than I thought it would. I tugged on it and it seems like it is holding real good. If the rain lets up I will pull it out of the garge and take some pics.
If the backside of the valance is unpainted it is a good idea to use an adhesion promoter for the double sided tape after cleaning it with the alcohol.
The release agent is very hard to remove, the adhesion promoter is just extra insurance. Any auto paint supply store will have this and it is available in a rattle can.
Originally Posted by Jeremiah
Killer car!
Im a sucker for Hugger orange, heres my 69 RS/SS I sold recently.
