Need halo wiring help....
I just wired up one of my halos. I ran the red wire to the purple fog light wire, and ran the white wire to the radiator support for a ground. Didn't work....so I changed the ground to the other fog light wire....still don't work? I used those little wire blocks that you put the wires in and close them up and they crimp down. Was that the problem? Do I need to do something instead? I am kinda lost as to what I did wrong, wiring seems good. Any ideas? How exactly did you all wire them up? Thanks!
Originally Posted by Lithium
huh? thats wierd. I just installed mine and did the same thing and it worked for me. When you gounded the white wire did the lights come on at all?
Nope, nothing......maybe I just need to check the connections.
You used those same kinda connectors?
What's not working? The headlights or the Blue halo's themsleves? You CANNOT see the halos during the day. make sure you connections are good and twisted straight.
SSU's Drunk Typing Whore
The halos, the headlights work fine.
I'm gonna make sure the connectors are fully crimped tommorrow.
Thanks so far for the help guys.
did u also make sure that the halos worked before you did all this, bc you should always test them before you go through all the trouble of wiring and stuff. but as for my halos i just ran them to an independent switch and they work fine, grounded them to the bolts on the fram right next to the air intake.
