auto headlight disable
im sure this has been asked 1000 times, and ive tried searching but found nothing. i have automatic headlights in my 1998 z28, as soon as it gets slightly dark my headlights automaticaly come on. when the car is on i cant turn them off. could anyone tell me how to bypass this? thanks
LS1Tech Administrator
Received 1,492 Likes
Originally Posted by NxLS1496
thanks!
And welcome to the site!
Originally Posted by ApacheDrill
If you want to do it the easy way.. Lift your emergency brake up one click, before turning the key on. It will disable the lights and wont effect the car...
Originally Posted by Sgt. Spuds
So why don't we want our lights coming on? lol
Shirley Temple Drinker
I always liked seeing my car comedown the auto carwash with the headlights on lol, well, not my car, my dads cars though...
No flamming needed for using the automatic carwashes, thank you.
some advice for what it's worth...it would be a lot better to take out the cd player and get to the sensor that way in my opinion...i have pretty big hands and back when i tried this by going under the back platic dash piece i cracked it and it's pretty expensive....just my 2 cents
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by RPM WS6
Okay what i got from this is to ONLY DISABLE THE AUTOMATIC HEADLIGHT feature you only have to remove the sensor on top of the dash and place a piece of wire into the connector?? Could you also just remove the sensor and tape up the connector?
I just cut the sensor off and spliced the wires together. I've had it like this for over 3 years now and it's not caused any problems. I never added any wires or resistors like a lot of guys say you have to.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
took me 15 minutes..put a cotter pin in the 2 holes in the sensor and elec. taped it up..silly to go through stereo..just lift pad on top of dash...E-brake method is a pain in the *** .....light is on inst.panel also that way.
