Those with the 69' style Z28 emblems...
Hey fellas, I just got my emblems in from work & noticed that they have a slight curve in them... Do you just pop them on or try flattening them out some??? Also do you recommend using the pins & nuts or grinding them off & use double sided emblem tape.. Thanks in advance!!
Mike
Mike
i used a dremel and cut the pins off and then used 3 m tape....and after i cut the pins off i put mine in between 2x4s with a towel on top and smashed them down then they fit great hope this helps
Originally Posted by MM98
Cool, thanks man... I've already got the pins ground off, but wasn't sure if the emblem would break if I tried to straighten it... I'll try your method & see what happens... Thanks again!
I didnt do anything with the curve on mine, I just cut off the pins, used some 3M tape, and stuck em on. Theyve been there the last 2 years with no problems, looks fine to me.
i wanted to run them but i and saw that they dont fit good under the reAR tail light and i didnt feel like cutting the pins and putting 3M tape on it so i just got these
