HID Headlamp Assemblies for 98-02 Camaro's?
TRY THIS ONE http://www.xenonking.com/index.html YOU CAN ALSO SEE THE DIFFERENT OUTPUT COLOR ON THE DIFFERENT NUMBERS
Copy & Paste Moderator
Here is a old thread:
https://ls1tech.com/forums/showthrea...ght=camaro+hid
And the pics of the HID Projector retrofit:
http://community.webshots.com/album/116863233uyEamc
Here is the recent thread about where the guy is considering making a retrofit:
https://ls1tech.com/forums/showthrea...&highlight=hid
I don't think anyone makes a housing for HIDs. The guys with camaros that have converted to HID either did a retrofit and put projectors into the stock housing or else they did it the not so good way of putting a rebased bulb into the stock housing.
If you have any specifc questions let me know. I've been studying HIDs for a few years now.
-Geoff
ya, I just put the 9006 hid bulb in the stock housing, kinda blinding if you dont aim it correctly but, after ~2 years I never got pulled for it, hella ballasts but dunno what kinda bulb it was, 9000k I believe, photos of the color of the bulb in my sig.
Originally Posted by White_Hawk
I'd be careful about doing this. With that big hole in the back of the lamp that it will probably be permanently fogged up.
-Geoff
-Geoff
Originally Posted by JasonWW
Keep in mind that the bulb area is still sealed up. The only venting is the factory vent, so it should not develop moisture or fog up.
-Geoff
OK, I think your specifically refering to RoadKnights install, he used a sealed Hella projector which isn't necessary, but I'm pretty sure he did seal it completely in the rear. The factory adjustment mechanism should be used to adjust the lights. I don't see a pic of it sealed in the rear, but I don't think he left it open. That would be rediculous. Water would get in there for sure.
And yes, the factory does make sure the whole assembly is sealed completely and then they install their own specific style of vents. Some designs use a rubber tube that is inserted near the top and then turns down to keep water out. Sometimes it is a smooth hollow tube and sometimes it has small zig-zag ridges to help dust stay out. Sometimes they add a small charcoal filter to also help keep dust out.
Some of the newer headlights use a special vent that looks like a circular bandaid about 3/4" in diameter. It is a special breathable material that just sticks over a hole. It repels water and dust.
Some use a vent that looks like a plastic cap about 1/2" in diameter. A hollow plastic tube is inserted into the top and then the cap pops on over it. There is a small gap around the edges that allows air to move past it.
A vent is necessary to prevent the hot air from building up and causing damage and to help equalize the air pressure.
-Geoff
