Califorina Car duster....Any way to clean and treat them
That is what my Meguiar's one says as well. However, I have shaken and quickly twisted it around with my wrist and it lets loose the dirt/dust. However little pieces of the fibers go with it. I don't really like it all that much because the strands are coated with wax and once I go across a panel, it leaves dozens of little wax trails and small bits of the fibers - kinda rendering it useless.
Originally Posted by ulySSes
I heard that you're supposed to keep them wrapped in newspaper when not in use. Is this true and why?
'Bird Director
I've used the same one for several years with great results. The comment about it working better the dirtier it gets is very true. The key to preventing the wax streaks is to not dust the car when it's in the sun, recently been in the sun, or right after being driven.
I have had a few dusters over the years. I've sort of made it an unofficial habit to replace it every five years or so.
Originally Posted by FH212
When you first buy them lay them on newspaper for a couple of days.That removes the excess wax in the duster.You probably will get little wax trails the first few times you use it but they will stop.After that they work great.
I have one and I really love it. It works perfectly in this dusty *** state. Fortunately I have a garage so my car isnt scorching hot when I dust it off. That is probably why some of you are getting wax streaks. I think even in the instructions it tells you not to dust it in direct sunlight, but Im not sure. Ive had it for about a year and yes its dirty as hell, but it keeps doing its job like a champ, no scratches or streaks here.
Definatally shake it after and during use to get the nasty stuff you just got off of your car off of your duster. We use ours at car shows and such. Only use it when your car is JUST dusty and NOT dirty!!
Originally Posted by onyx_rock
I washed mine in our washing machine and put it back on and it worked better than before. I believe it actually says you can machine wash it on the instructions.
I never realized your not supposed to use it in the sun, most the time my car has been sitting outside before dusting, and I constantly have the streak problem, then I have to go over almost the whole car with quick detail to remove all the marks, basically it makes 2 times the work. Next time Ill try it before taking it out in the sun
What did you use in the wash for detergent?
