Sponsored by: DashLynx
View Poll Results: Scratch X by hand - did it work?
Yes - My scratches are gone
12
16.22%
For the most part, but some scratches still remain
24
32.43%
No - My scratches are still there
38
51.35%
Voters: 74. You may not vote on this poll
Scratch X by hand - did it work for you?
Old 04-16-2006, 07:19 PM
BlackHawk T/A's Avatar
Question Scratch X by hand - did it work for you?
As it says. Were you successful in removing light scratches/swirls/cobwebs from your clearcoat? Also post your results and your process.
It would also be helpful if you listed the year of the car you were working on and how bad of a condition it was in before you started.
Old 04-16-2006, 07:24 PM
cooltc2004's Avatar
Didn't work for me.
Old 04-16-2006, 07:30 PM
BURN'EM's Avatar
Save the cash.
Old 04-16-2006, 08:07 PM
So far 0/2...not good
Old 04-16-2006, 09:05 PM
Gipraw's Avatar
my comment to them would be either it was not used correctly, or used on something it was not designed to correct.
ScratchX is one of the best scratch removers I have ever used, and it is one of the first things I pull out of my bag when I am working on a car. I will almost always hit the trouble spots with ScratchX prior to starting work on entire panels.
For those of you that say it didn't work.. what were you trying to do with it, and how did you go about it?
Old 04-16-2006, 11:15 PM
Kman's Avatar
I followed the directions here.
http://meguiarsonline.com/forums/sho...&threadid=7011
Seemed to remove some of the scratches. I'm happy.
Old 04-17-2006, 12:42 AM
epic's Avatar
Did an okay job. Definitely didn't remedy all of them, but it helped a little. I usually use it on my tail-lights only..
Old 04-17-2006, 11:21 AM
ZaneO's Avatar
ScratchX does have some cleaners and light abrasives and will remove *some* defects, but it also contains fillers, etc., so there might be more left than you see.
Old 04-17-2006, 05:35 PM
firefighter's Avatar
I've used it for over a year now and it let me down ONLY one time but I was pretty sure that it wasn't going to get out the scratch anyways I used some Med Cut cleaner and followed it up with the Scratch X and it was all better then. You gotta use the right product for the job.
Old 04-17-2006, 06:02 PM
Y2K Pewter SS's Avatar
Had no luck with it either
Old 04-17-2006, 10:07 PM
2_wacko's Avatar
A waste of money.
Old 04-17-2006, 10:44 PM
MountainMotor's Avatar
It didn't do a bad job on my old '95 TA. I had some light swirl marks on the hood and it took out the majority of them. The car was in great shape when I started thought.
Old 04-17-2006, 11:00 PM
cooltc2004's Avatar
Was used on a brand new truck, where it looked like something brushed up against it. Wasnt deep, wasnt even that noticeable, but I followed the directions on how to use it, and it did nothing for me.
Old 04-17-2006, 11:17 PM
Luna's Avatar
You really have to rub it hard and fast to make it do anything, but even then , its usually a flop for me.
Old 04-17-2006, 11:21 PM
CajunCC's Avatar
*ahem* BWAHAHAHAHAHAHAHAHAHAHAHAHAHA
Old 04-17-2006, 11:24 PM
Luna's Avatar
I knew someone was going to take that out of context
Old 04-17-2006, 11:57 PM
Onyx Z's Avatar
Once the stuff dries after rubbing it for a while, it will not work as intended. It can't dry out while using it.
Old 04-18-2006, 12:28 AM
SleeperZzZ28's Avatar
after viewing that link Im going to have to give this stuff another shot. I need to pick up that polish also.
Old 04-18-2006, 12:59 AM
Kman's Avatar
Make sure you guys use these steps.
http://meguiarsonline.com/forums/sho...?threadid=7011
Old 04-18-2006, 08:41 AM
SladeX's Avatar
it does work, but you have to use a hell of a lot of "effort". I think the deep crystal polish is a good step to follow as well and may try it in future.
Quick Reply: Scratch X by hand - did it work for you?
