Sponsored by: DashLynx
10000K HID Kit and LED Map Lights installed.
Old 04-27-2006, 09:08 PM
317indy
Guest
Posts: n/a
Default 10000K HID Kit and LED Map Lights installed.
The lights are bright as hell, blue, but still bright. Just the way I wanted it. The LED's I got from a sponser. The rear dome light that was sent didnt work. It uses a diffrent kind of light I guess :-(.
The pictures dont do the lights justice. Yes I know the glare..the glare..blahh blahh blahh. Ill fix that in a few days. Next up is the 885 50W Xenon Foglights HID look.
Old 04-27-2006, 09:55 PM
NxLS1496's Avatar
looks good
Old 04-27-2006, 10:26 PM
sdm1234's Avatar
I think red LEDs would compliment your car more, with the red exterior.
Old 04-27-2006, 11:12 PM
317indy
Guest
Posts: n/a
They arent blue, they are the "white" ones lol.
Old 04-27-2006, 11:30 PM
huskerpower02's Avatar
What kit did you use (where did you purchase it from) and how hard was the install?
Old 04-28-2006, 12:10 AM
Moderator
nhra-trans-am's Avatar
that looks pretty good.
Old 04-28-2006, 01:46 AM
_JB_'s Avatar
Pretty sweet, but always need more pics!
Old 04-28-2006, 03:53 AM
1SicV8's Avatar
can u give me the link for the map lights?
Old 04-28-2006, 05:58 AM
SRZ
SRZ's Avatar
Ditto on the info for the light kit etc. Thanks!
Old 04-28-2006, 06:56 AM
01RedT/A's Avatar
What do you plan on doing to fix the glare? Im a big fan of the color, i wanted a 12k kit on my t/a, until i did the research. i still want one but probably wont ever use it now..
Old 04-28-2006, 12:09 PM
317indy
Guest
Posts: n/a
I got the lights from LS1_SS www.ledgauges.com
I got the HID Kit from a non sponser so PM if you want that info.
Install was really easy. Took me all of 15 minutes to install. It comes with a wiring harness that plugs into the ballast's and the ballasts plug into the back of the lamphousing then you plug you factory plug into the harness. It comes with a relay and inline fuses. Really quality kit! 270$.
I plan on using some high temp paint to make a cutoff line so that it doesnt affect people that look directly into the lights.
Old 04-28-2006, 12:27 PM
Breathtaker's Avatar
Looks good, PM me with HID kit info please.
Old 04-28-2006, 12:44 PM
Thx man for the link, that HID kit looks awesome, thinking about purchasing it now, thx again for making me spend more $$$ on my car!
Old 04-28-2006, 12:49 PM
qwikz28's Avatar
dont think, just do it. nathan is the man and his work is top notch. definately worth every penny
Old 04-28-2006, 02:27 PM
Bad Blu Formula's Avatar
Isn't 10000k illegal? Either way it looks badass man.
Old 04-28-2006, 04:04 PM
Blade's Avatar
Anything over 6000K is a waste of money, IMO.
Old 04-28-2006, 04:14 PM
According to the website of the seller, from 4300k to 10000k it is the same price for the HID kit which is 230 bux.
HID retrofit kit which includes:
2 HID bulbs (xenon)
2 Balasts (water proof)
All neccessary wiring and hardware
Detailed instalation instructions
You pick the HID bulb temperature color. Please specify when ordering.
4300K
5000K
6000K
8000k
10000k
*Please note: The brightest temperature is 4300k, higher temperature means bluer color of the light.*
Old 04-28-2006, 06:13 PM
317indy
Guest
Posts: n/a
Actually its 4600k that is brightest. That is what Mercedes use and 6000k is what BMW's use. Im getting some 8k High beams next!
Old 04-28-2006, 06:28 PM
horsekilla 95TA's Avatar
What did you use for the MAP lights are they the 194's?
Old 04-28-2006, 06:30 PM
jorgez28's Avatar
can you pm where to buy that kit
Quick Reply: 10000K HID Kit and LED Map Lights installed.
