Sponsored by: DashLynx
Rattlecan paint question??
Old 09-08-2006, 12:09 AM
PunishedU's Avatar
Default Rattlecan paint question??
I was trying to paint some extra interior peices that I had lying around. First, I sanded the peice until all of the texture was off and ended up with 320. Then I used Bulldog adhesion promoter and did a light coat and then a medium. Then I used a duplicolor primer, heavy build, and sanded that smooth with 320. Then I used High temp black spray can paint and did 6-7 light to medium coats. This is where I had a problem. I noticed that the paint dried with a texture. I wondered if it was because that type of paint has ceramic in it to help with heat. Then I sanded that down from 320 and finally ended with 1000. Then I used a high temp clear with ceramic and after 6-7 coats, it dried with some bad orange peel.
What did i do wrong and what should i do about the orange peel. What should I sand it with and then polish it with.
Thanks for the help, and I'm glad I tried this with some extra interior peices.
Old 09-08-2006, 12:52 AM
98hardtopZ's Avatar
try wetsanding the clear, you have to do that normally anyway....
Old 09-08-2006, 02:03 AM
1SicV8's Avatar
wet sand the clear then try buffing it....
or start over and follow these directions
https://ls1tech.com/forums/showpost....61&postcount=9
Old 09-08-2006, 02:08 PM
OnA Fan's Avatar
Wet sand with 2000, then hit it with ScratchX and follow up with NXT or whatever wax you prefer.
Old 09-08-2006, 02:12 PM
PunishedU's Avatar
Thanks for the help guys, I wasn't sure what to start sanding with and what to polish it up with.
Old 09-09-2006, 01:49 AM
PunishedU's Avatar
https://ls1tech.com/forums/appearance-detailing/572849-rattle-can-paint-results-small-interior-piece.html
Quick Reply: Rattlecan paint question??
