what degreaser do you use on your engine bay???
Ok well this past weekend i cleaned up my engine bay, and i went and bought some degreaser from advance. I put it in a spray bottle and sprayed it all over the engine bay, but it was hot and i think it dried before i put the water on it so i sprayed it down again with the degreaser and then sprayed it off with water. Now it has like a dull look on the heads and valve covers. I was wondering what kind do you guys use that is strong enough to actually eat grease and whatever else might be on there?
thanks
B.J.
thanks
B.J.
i did drive it about half a mile to get the degreaser but then i let the car sit for bout 30 min before i did it also. maybe thats what caused and i need to do it again when its cold. i cant remember what i used ill have to get a look at it when i get home.
I always let my car sit all day or overnight before I tackle the engine. I have a Mustang that I show and have used Purple Power, but have discontinued use since I was worried it would discolor my intake manifold. Simple Green works pretty good, but I just bust knuckles and elbows with plain old water, a toothbrush, hard plastic scrubbie brush and wet rags. It takes longer, but I don't have to worry about getting water where it doesn't need to be - did that once. Had to let the mass air flow plug air out overnight to get the car to crank.
Originally Posted by Bird Man
My bay never gets too dirty --- so I put some Dawn liquid in a spry bottle with a small amont of water and spray it on the greasy parts . works nice.
Originally Posted by EvilBLK02TA
Plus if you stay up with it and keep it clean, then it makes it a lot easier next time around you want to do a full detail
