Sponsored by: DashLynx
Anyone have NR white faced gauges?
Old 10-22-2006, 09:54 PM
Z95m6's Avatar
Default Anyone have NR white faced gauges?
I searched and searched for a gauge overlay that would fit 97-98 Camaros and found nothing except the Macewens which have terrible service and don't even have the factory style. I finally decided to go with these
http://speed-eng.com/store/product_i...oducts_id=2151
The only thing that sucks about these is that they're not a gauge overlay, you have to remove your whole gauge face and replace it with theirs. So its actually a much higher quality deal. Does anyone have these? I have a laptop and scanning software so the only gauges i have to worry about getting correct is the fuel and oil pressure. Anyone have any input on them? I hope to have them installed by the weekend.
Old 10-22-2006, 10:19 PM
SSNISTR's Avatar
I actually have them, they have been on for years. Take your time putting them on, and make sure you put the needles on EXACTLY how they were. These are very high quality, and well made. Just a PITA to install, but worth it. Also, add the T/A bezel at the same time.
Click the link in my sig, there is one shot of them on my page.
Old 10-22-2006, 11:19 PM
Z95m6's Avatar
Good to hear. Do they actually light up blue? i figured they would be like stock blue tint plus our yellow bulbs = green. I'd really like for them to be green actually when they're illuminated because if not i have to change the whole interior to blue to match them. My buddy also has a 97 so i think when i'm putting the needles on i can put his cluster in and double check where they should be at then install my needles.
Old 10-23-2006, 08:10 AM
Teri9672's Avatar
I have them on my 02 SS
Old 10-23-2006, 11:14 AM
01Z28MN6's Avatar
yeah i have white faces guages where i had to remove the needles. Just be sure to note the exact spot, with the power switched on, and make sure you get them back on exactly where they were taken off. Otherwise you just have to learn the new position. LOL.
Love the look of mine, they light up blue at night.
Old 10-23-2006, 11:29 AM
Z95m6's Avatar
Thanks Teri it seems that even though these aren't an overlay they still light up funny around the needle just like all white face gauges. They also look kind of like a blueish green tint too. I sure hope they don't come with NR on them on the tach though. I called and friggin asked the lady at NR and she said it had NR on them but not in a visible spot. So hopefully the 97-98 Camaro one is different. Now i just need to get a TA Bezel but i need to find a place beside Macewen to get one.
Old 10-23-2006, 01:24 PM
Teri9672's Avatar
good luck... they are a discontinued item. We had stock of about 50 of them at one time, but we sold them all.
Old 10-23-2006, 01:29 PM
FirehawkNS's Avatar
Mine are 97-98 Guage overlays (Reverse EL). I didn't realize they were not for 99's until I got them home. No biggie, I just lost the High beam and oil change indicators.
Terri got me the bezel. These have been in for about 3 years now at least.
Old 10-23-2006, 03:06 PM
Z95m6's Avatar
Oh really, thats good info to know. I need to jump on getting one ASAP. I'm tempted to just buy a nice used V6 firebird cluster so i can get the bezel and have a spare digital odometer to try to put an LED in.
Old 10-23-2006, 04:26 PM
SSNISTR's Avatar
They must have added that, mine do not say anything.
Old 10-24-2006, 03:19 PM
bww3588's Avatar
how did you get yours with the SS and camaro emblem on yours? BluCamSS?
and what is the best way to get the needles back in the right spot?
Old 10-24-2006, 03:38 PM
Z95m6's Avatar
Go to cz28.com and check out Brent Frankers site. I'd post the link but it would get shut down.
Old 10-24-2006, 08:40 PM
3.4camaro's Avatar
turn the car on and note the position of all the stuff. note RPM, voltage at idle, where the speedo sits, oil pressure, fuel, and temp when its warmed up.
do your thing
then put em back on once the car is warmed up again
Old 10-24-2006, 10:33 PM
bww3588's Avatar
so i should put the needles back on after i get the cluster back in and the key on?
Old 10-31-2006, 02:15 AM
Z95m6's Avatar
Well i got the gauge face and finally got around to installing it. The procedure was kind of a pain but they're well worth it. They look great and light up nicely. They were even cheaper than most overlays, and the quality is second to none. My buddy with his Macewens was drooling over my new NR guages. Setting the needles was a little tough.
I just let the car get cold and i started it up and made a diagram of where all the needles needed to be. Then when i got done installing the new face i started the car and put the needles in the correct place. I also have a laptop so i actually "calibrated" my tach and my speedo as they were off a few mph from the factory.
Old 10-31-2006, 03:34 AM
bww3588's Avatar
so actully, it would be beneficial to take a picture of the gauge cluster while the car is running and put the needles back on like the picture while it is running?
Old 10-31-2006, 12:27 PM
Z95m6's Avatar
Yeah i guess but i really don't see anyway you could set the tach and the speedo. Well i guess if you know what rpm your car idles at you can get that correct but i think the only way to get the speedo correct would be with a GPS, a laptop/scanmaster, or someone pacing you.
Old 10-31-2006, 01:11 PM
bww3588's Avatar
the speedo wouldnt be hard, just put it back on while the car is off and let it rest against the part that the steering collumn goes through.
Old 10-31-2006, 01:21 PM
Z95m6's Avatar
Haven't you ever noticed that when the bezel/lense is off the speedo needle will keep on falling past its original stopping point.
Old 10-31-2006, 01:40 PM
bww3588's Avatar
ahh **** i didnt think about that.....a picture would be the easiest way IMO
