Sponsored by: DashLynx
Just bought these what should i do????
Old 11-29-2006, 10:17 AM
stdjsw311's Avatar
Default Just bought these what should i do????
ok i just bought these
http://cm.ebay.com/cm/ck/1065-29392-...m=260056309850
should i grind the studs off the back and glue/double side tape it on or should i drill holes in the side of the car??? <<< Bad Idea!! i dont know what i want to do!!!!
thanks
Old 11-29-2006, 10:19 AM
Z28LS1camaroguy's Avatar
most guys just take the fenders off and drill the holes that way you wont risk them coming off, since they are heavier than the regular emblems. Just tape around the stock Z emblem that way you know exactly where it was and then place the emblem down mark where the holes are and drill.
Old 11-29-2006, 10:32 AM
stdjsw311's Avatar
so i do a smaller hole so it will wedge in there??? if i do that i think i will do both tape and holes
Old 11-29-2006, 10:52 AM
i think you might want to drill the holes perfect to specifications, bc you dont want to shove them in there and then crack the fender or chip paint off.
Old 11-29-2006, 10:59 AM
GR33N GoblinM6's Avatar
i used 3M double sided emblem tape.. same kinda stuff the factory uses... mine are on there like cement... dont drill the fender
Old 11-29-2006, 11:03 AM
stdjsw311's Avatar
i think i may just do the double sided tape. did you just grind off the studs on the back??? the way the studs are designed are for the older cars with metal fenders and were designed to be wedged in, but our car have plastic fenders and wont work the same i guess.
Old 11-29-2006, 11:06 AM
yeah.. all i did was take my die grinder and used a cut off wheel.. and cut them off flush... took about 1 min.. the metal is not hard. I dont know of anyone that has drilled holes into their fenders.
Old 11-29-2006, 11:07 AM
michaelg589's Avatar
Dont drill!!!!!!!!!!!!
Old 11-29-2006, 11:55 AM
texasreb18's Avatar
there is definitely no need to drill, just use the 3m tape and you wont have any worries at all
Old 11-29-2006, 12:04 PM
Z28-CTYHNTR's Avatar
Dont drill into your car man, theres no going back after you do something like that. All I did was hacksaw the pins off the back and get some double sided tape, they stayed on my car just fine for 3 years through 2 chicago winters. It'll be fine. DONT drill your car.
Old 11-29-2006, 12:09 PM
bigfoot2thefloor's Avatar
double sided tape will be fin just dont hold a pressure washer at point blank for 10 minutes and you shouldnt have a problem...
Old 11-29-2006, 12:14 PM
ss4chad's Avatar
I bought a cursive Chevrolet emblem off of a '57 Chevy, ground of the pins and used outdoor double sided tape to apply it and it worked great. No drilling required. I found that tape at Staples.
Old 11-29-2006, 12:15 PM
parbreak's Avatar
Do NOT drill into your car. What if you decide down the road you don't like them. Then you're screwed. Do what I did and dremel off the studs and then use 3M emblem tape. They will not come off, trust me.
Bryan
parbreak
Old 11-29-2006, 01:22 PM
unSStoppable's Avatar
cut the tabs off, grind smooth, and use some 3M double stick. You will feel much better that you did that if/when you ever decide to take them off.
Old 11-29-2006, 02:54 PM
stdjsw311's Avatar
Bryan
parbreak
yeah i thought about that because if i did the drilling (which i am not going to now) i would have to redo my flame job. i really dont want to do that! how did everyone get their existing emblems off??? drilling into my car would be like drilling into a national monument!
Old 11-29-2006, 02:56 PM
smg267's Avatar
Dear GOD don't drill them on!!! I cut the back of mine off with a god old hacksaw. Took like 2 mins then bought 3m tape from NAPA for like $2. just use a razor blade and cut the strips smaller so they don't stand out. Then you have to step on the emblems a little bit to get them to contour to the car fender. I simply stepped on them a couple times on the garage floor and they fit perfect. I learned that trick from a member on here. Getting the old emblems off was the biggest PITA!
Old 12-28-2006, 08:13 AM
FirehawkNS's Avatar
Are you referring to the fact that they are curved from top to bottom? I was wondering if my parents got me the wrong ones since I haven't heard anyone mention them being curved a little, but my 69 emblems are. So I need to flatten it out some in order to fit them? Didn't want to cut the tabs off if they got the wrong ones before finding out.
Old 12-28-2006, 01:52 PM
They are curved a tiny bit. I didnt even bother trying to flatten them and Im not sure there is a way. Once they were on they looked fine, and you can not tell they are curved. And no, they never fell off, they were on my car for 3 years before I took them off and they were a bitch to take back off too.
Quick Reply: Just bought these what should i do????
