Sponsored by: DashLynx
LS1 to LT1 taillights
Old 01-06-2007, 09:06 AM
LS1DER's Avatar
Default LS1 to LT1 taillights
And yes I did some searches first, but didn't find anything about the wiring harness. Other than some fitment issues with the bulb sockets do I have to do anything special? Can I use my existing wiring harness? Just wondering if it's a plug and go or if I have to do any modifications. Thanks for the help.
Old 01-06-2007, 09:19 AM
mySStery_machine's Avatar
I am not a fan of the LS1 lights and swapped out for a set of '94 or '95 lights about two years ago. I like the look much more and would never go back. A simple trim on the housings was all it took to get the bulbs in (rampant corner). I think I installed the bulbs upside down to make intall easier and less trimming if memory serves correct. I like the look of my '94 Z's rear and really love the power of the LS1 so it all works! Besides when people 'in the know' come up on what they think is a older Camaro they are shocked to see the new front clip.
Old 01-06-2007, 09:31 AM
LS1DER's Avatar
So you don't have to mess with the wiring harness any? Just do some trimming
Old 01-06-2007, 10:52 AM
That's about it!
Old 01-06-2007, 11:30 AM
LS1DER's Avatar
All right thanks. Now I need to find some LT1 taillights. Anyone want to trade my ls1 for your lt1 lights?
Old 01-06-2007, 02:19 PM
Jakson's Avatar
I wired mine up differnt so the turnsignal bulbs stay on low filament, like the LT1's do. I just bought a GM socket at the store and took 2 of the wires out. Then i put them into the empty slot on the current turnsignal sockets and then tapped into the low filament wire on the main tail light socket.
Looks alot better with the whole light lit up rather than just the outside corners.
Before:
After:
Old 01-06-2007, 02:22 PM
StrobinSS's Avatar
Before:
After:
Wow you did too much.
Old 01-06-2007, 02:24 PM
StrobinSS's Avatar
Only if you want the tails to light up like in my sig will you have to mess with the wiring. And one wire and a scotch lock per light is basically all you need.
Old 01-06-2007, 02:25 PM
Mistacamawo's Avatar
I have the LT1 lights also, didn't mess with any wiring just trimmed a bit of material off of the lights and the bulbs go in. Very easy mod to do.
Old 01-06-2007, 02:27 PM
Jakson's Avatar
I just wanted to make sure i had a good connection so i bought another socket and used them wires. I guess i could have just did it like you did, but mine is better
Old 01-06-2007, 03:45 PM
LS1DER's Avatar
When I get some I will definately do that. Looks good jakson and strobinss
Old 10-08-2008, 01:23 PM
onebadredss's Avatar
So can someone take a pic of whats needed 2 do... i kinda don't understand from how you guys are explaining the modification it takes
Old 10-16-2008, 02:17 PM
bump...
Old 10-16-2008, 03:56 PM
f-tothe-ill's Avatar
No pics, but disconnect battery and unbolt the taillights. On the turn signal bulb housing there are two wires and a green plug in the middle hole I believe, take out the plug, put a piece of wire into the slot and shove the plug back in it, then splice the other end of said wire into the brown wire on the brake/tail housing bulb. Reconnect battery and turn on lights. Done.
Old 10-16-2008, 04:05 PM
Banned Village Idiot
LS1BLKSS's Avatar
i like the lt1 tail lights, they flow better with the camaro
Old 10-16-2008, 04:42 PM
Thanks man i will see later today what u are talking about
Old 10-16-2008, 04:47 PM
Jakson's Avatar
I got a couple pics here. You can see how i tapped into the middle wire with the scotch lock and ran that to the middle of the turnsignal bulb socket which is empty. That way it powers the turnsignal bulb on low filament so it comes on with the lights on low, then still blinks bright. Let me know if you don't understand it.
Old 10-16-2008, 10:37 PM
Ya i understand cool thanks a lot easier then i thought... now can you show me what i have to do to the housing?
Old 10-17-2008, 06:12 PM
Jakson's Avatar
Its self explanatory once you look at it compared to the bulb sockets. Just get the dremel or something out and it will just take a second.
Old 10-20-2008, 01:28 PM
sweet this should look sweet!
Quick Reply: LS1 to LT1 taillights
