Sponsored by: DashLynx
t-top noise
Old 01-27-2007, 05:03 PM
vatechguy3's Avatar
Default t-top noise
i've had my 2001 z28 for 3 weeks now and there is an annoying noise coming from the passenger side t-top. i thought it was the forward pin rubbing on the plastic a-pillar. so i pulled the a-pillar and screwed it back so it was correctly centered on the pin bracket.
no joy in elimanating the squeek!!
suggestions on what to try next??
thanks!
tony
Old 01-27-2007, 06:04 PM
mycamaroSS's Avatar
yea, whenever its cold out my ttops make a little crackle noise very annoying
Old 01-28-2007, 09:42 AM
vatechguy3's Avatar
has anyone found a fix for this?
thanks
tony
Old 01-28-2007, 10:43 AM
johnpr's Avatar
i havent had this problem but mybe its just because the rubber weatherstriping is cold? just a thought. sorry i couldnt be more help
Old 01-28-2007, 11:16 AM
osvaldo's Avatar
maybe cleaning the t-tops and the weather striping would help
Old 01-28-2007, 11:25 AM
LANDONZ's Avatar
i have the same problem.. everytime I turn or go over any bump with just one side of my car, like a speed bump or something. Its makes a crackle noise. Mine soounds like it coming from inside the t-top itself thought
Old 01-28-2007, 12:46 PM
6SSPEED's Avatar
I have the same problem. If you squeeze near the keyhole it "crackles" the worst. I took it apart but could not figure out where it was coming from. I hope someone finds an answer to this annoying problem.
Old 01-28-2007, 01:47 PM
Kman's Avatar
It's the frame of the car moving around the t-top that is causing the bad noise. Next time you go over a speed bump or dip or whatever put your finger in the gap between the t-top and the a-pillar. You should feel the t-top move.
Mine used to make noise. When I put the UMI 3-point bolt-in sub-frames, they don't make noise anymore because the frame is a lot stiffer now.
Quick Reply: t-top noise
