ok got a stupid question someone help!!
Originally Posted by CULATR
i bought a set of clear corners and they keep getting condensation in them so where did you drill the hole at on the corners where its not noticable on your clear corners ??? anybody??
I just put some tape on the tops where the bulbs screw in. Stopped it....
i wanna drill the holes but i just want to know where you put drill them so it cant be seen and from someone that done it and it worked ..........anybody?? though however i will put tape on the tops like you did lol every little bit helps in this case ....so thanks for the idea ..
Originally Posted by bene
Drill it on the very far corner (where the water gets collected)and make sure the hole is tiny.
Originally Posted by Blk97WS6
+1. thats were i put mine. no one even knows it theres. and i havnt had one bit of condensation since doing so.
Ok is that on the pointed edge of the lense or the other side in the corner???
mines fogging up in the pointed corner on both my lights close to where the small 194 bulb is ..........
