Rear bird removal
Rear bird removal
Whats the best way to remove the "Trans Am" and bird logo's between the rear tail lights?
Also, can they be removed to where you couldn't tell they were ever there?
i can't get past the rubbing alcohol step, ive been rubbing on it for awhile without any results. Do i need stronger rubbing alcohol? right now the alcohol im using is 50% alcohol, should i try to find something stronger?
i just did this about an hour ago and i should've done it 5 years ago. looks great. I didn't use any solvents first i just started with 1000grit sand paper(wet) and it came of within a minute. finished it off with 1500 then 2000 and buffed with meguires plastic polish.
