Sponsored by: DashLynx
gauge bird
Old 03-29-2007, 11:39 PM
Stealth00T/A's Avatar
Default gauge bird
where can i get one of those little birds that go on the gauges it looks almost factory. didnt see anything out on the net. any help would be appreciated
Old 03-29-2007, 11:45 PM
JTH2000SS's Avatar
ws6store.com sells a complete overlay with one on it
Old 03-30-2007, 06:19 AM
onefastbird95's Avatar
you can buy the decal from ws6store are well its like 10 bucks.... I bought the macewen gauges from them and got the bird decal and put in on myself... looks great in my opinion!
Old 03-30-2007, 09:34 AM
1meantransam's Avatar
how hard to put on?
Old 03-30-2007, 10:56 AM
very easy... there is a clear top layer that the bird decal is stuck to and a bottom layer that you peel off. You just allign where u want the bird, press down on the clear layer and then peel the clear layer back and the bird decal has been transfered over.
Old 03-30-2007, 01:03 PM
Flamin' bird's Avatar
Ditto. Did the same thing years ago. A friend made the bird and Formula decal for me.
Old 03-30-2007, 03:33 PM
how hard is this dash to get apart i havnt even looked, i know my honda took all of 2 mins soo
Old 03-30-2007, 03:42 PM
Just pops out via spring clips. Pretty easy. Make sure you disconnect the foglight switch from the harness as the trim/switch are attached to the dash surround. I had trouble with mine
Old 03-30-2007, 03:43 PM
LS1obsession's Avatar
Brent Franker
Old 03-30-2007, 04:32 PM
when You remove the dash its kinda tight around the stearing column... You kinda have to contort the plastic pannel when removing it, and also watch dragging the clips across the clear plastic on the bezel because of the snug fit. other than that it was pretty simple.
Old 03-30-2007, 05:01 PM
transambandit's Avatar
Originally Posted by LS1obsession
Brent Franker
whered you get that black part that divides up the gauges?
Old 03-30-2007, 05:05 PM
That's the stock t/a bezel. They sell them with the MacEwen Camaro gauges.
Old 03-30-2007, 11:06 PM
'02 WS6's Avatar
that's what i got. they're noiice!
Quick Reply: gauge bird
