Sponsored by: DashLynx
How to wet-sand headlight?
Old 05-18-2007, 11:10 AM
HarvDrivesGM's Avatar
Question How to wet-sand headlight?
I know there is a thread within the hall of fame one about yellow/cracked headlights and this does relate to it. However it said he wetsanded with 400,800, then 1500 grit or whatever.
My question is, how do you wetsand? what is the proper technique to make sure i don't do any more damage to my headlights?
Old 05-18-2007, 11:29 AM
BIG_MIKE2005's Avatar
Keep it wet the entire time. Hence the name "wet sanding". If it dires out you'll see swirls from build up on the paper.
Old 05-18-2007, 12:54 PM
Blackbirdws6's Avatar
keeping it wet is key as said above but even pressure and attention to detail are very important also. Take the time to work all the imperfections out and work your way to the finer grit paper. Finish them off with a plastic polish to bring back the shine.
-brian
Old 05-18-2007, 09:33 PM
wilwhite2kss's Avatar
just to add to blackbirdws6, u might want to use a drill and pad to polish the lights. Hand polishing wont cut it.
Old 05-19-2007, 12:39 PM
orange1999ws6's Avatar
Location: rochester ny/ cannon air force base, new mexico
wetsanding only lubes the paper... it doesnt make the grit finer or anything... but wetsanding is just much easier... and as they said just keep it wet so u dont have build up that will leave bigger scratch marks or swirls..... and it would be best to use a buffer but be careful dont wanna burn/smear the plastic lens!
Old 05-19-2007, 09:59 PM
02silvaZ's Avatar
i used a drill with a cone-tipped bit to polish them out
Quick Reply: How to wet-sand headlight?
