Rained in my car(leather seats) help...
what can i do to speed up the process of it drying out and not ruin my seats...my window was about half the way down for about 4 hours of straight rain....its not actually as bad as i thought but two days later my drivers seat is still damp...id take it out and put it in the sun, but its still raining...what can i do to speed up the process?
thought about that, but its setting on E cause i came home that night at 3AM and no gas stations were open...and i really dont feel like getting my *** and back soaked again...but if thats what its gonna take and someone else doesn't tell me something soon, ill end up doin it
I'd recommend a more thorough approach...
Tore out my ENTIRE interior last weekend after standing water was found in foot wells of rear passenger seats (flash flood got water in there somehow).
It doesn't take that long and the car is 100% better, not to mention the relief of knowing your car is clean, dry, and not going to become a rust bucket.
I took out the seats, interior trim, and carpet. Drained what remaining water was in there through the plugs in the floorpans. Bleached the metal floorpan surfaces, tore off the old, wet carpet padding, steam-cleaned both sides of the carpet (bottom is rubberized), conditioned leather seats, replaced carpet padding (on reverse side of carpet) with new from Lowes and reinstalled everything.
1 hour to tear out (really quite straight forward). 4-5 to wipe down, steam-clean, condition, reapply padding, etc. And about 2 hours to put it all back in properly.
I'd recommend a similar process in your case due to the possibility of water under the carpet and sitting against the floorpans (it won't dry on it's own, trust me). It's COMPLETELY worth the effort and, as I said, I sleep a lot easier knowing my interior is clean and dry, both where I can see it and, more importantly, where I can't.
HTH,
-John
HTH,
-John
this happened to me a few years ago. same situation, windows were 3/4 way up and it rained overnight. It took about a week but everyday I would go out with a few towels and soak up the water in the seats and on the carpet. it wasn't a whole lot of water, I just kept doing it just in case there was any water left in the carpet.
yep take it out, water will sit under those carpets for a very long time and your interior will smell like mildew. Gotta just remove the interior. The coating on these cars is pretty good though so I don't think you have to worry about rust.
Concerning the seats, I have just run the heater with the windows cracked in the past.
Concerning the carpet, can you not suck the water through the pad and carpet into a good wet-dry vacuum? I helped an acquaintance prep a really dirty f-body for sale once. The carpeting looked quite bad. I soaked it in cleaner and used a garden hose to blast it in places. Then I vacuumed very, very thoroughly, and repeated. Let it sit in the sun for a while, and looked good as new. No problems down the road from any residual moisture.
...Concerning the carpet, can you not suck the water through the pad and carpet into a good wet-dry vacuum?
-John
