Sponsored by: DashLynx
Painting Interior (Pics inside 56K welcome)
Old 11-11-2007, 01:00 PM
TAEnvy's Avatar
Default Painting Interior (Pics inside 56K welcome)
Guys My car needs a new headliner, carpet, and a driver side seat.
Ive been tossing around the idea of wrapping the entire interior in leather to give it a more high class feel.
Another option Ive considered was painting all the interior panels with a semi gloss or matte plastic paint. Along with a true black headliner and true black carpet and new MRC seats.
Well I didnt want to tear the interior out of the DD and then have the paint look like hell, but today I had a local guy give me all of the panels out of a 95 formula.
They are all tan now, but tommorow I will be spraying them with some krylon fusion to see how they come out.
Also will be doing the insert of the firebird door in either leather or vinyl but I cant decide on a color. Silver maybe, something like a dark silver but not exaclt the stock color, charcoal.
Too dark to work on them now but Ill be gettin up bright and early tommorow before going to the track to work on them.
TAEnvy's Avatar
I got up early this morning to do a little work before going to the track and Ive got some pics.
Here you go.
Before
First attempt at a First Coat. Haha It took me a little to get used to spraying down instead of out
After
Heres the Paint Im using
Am I the only one that LOVES the new spray nozzle for rattle cans
A sample of my interior now
Old 11-11-2007, 01:01 PM
TAEnvy's Avatar
It will be a while until its done cause the door panels are gonna take a little bit of time since I need to wrap the center section (TA Panels) in leather and get some vinyl paint for the doot handle strip dealy haha
Old 11-11-2007, 03:30 PM
2ToNe04's Avatar
Looks really nice, it looks as if they were leather or something. Nice job!
Old 11-11-2007, 04:16 PM
transampimp's Avatar
Looks good, however I've had bad experience with that stuff actually staying bonded to the surface. My buddy used that stuff, and his car smells like rattle can paint every time its hot out.
Old 11-11-2007, 04:45 PM
TAEnvy's Avatar
UPDATE
The track trip got cancled so I decided to do a little more work.
Pics
And I have some questions.
How do I take off the board on the back side of the door panel. I see some little clips, do I just cut those off, but then how do I put the panel back in. See Pic
Then I started looking at the door panels and Im trying to plan a mod of attack.
The tan outer part (1.) will be painted since its plastic.
What color and material do you think I should do the insert (2.)in , Im thinking maybe suede or leather and a dark silver or a color slightly off the paint color. What do you think?
What should I do with the vynil handle (3.)? Ive heard of vynil paint flaking off pretty bad, should I just wrap it in a black leather or do any of you have any better Ideas? Could I dye it?
Old 11-11-2007, 05:00 PM
greendrazil's Avatar
I've been through painting the entire interior. I used Duplicolor paint for vinyl & etc. The vinyl handle area doesn't so much chip or crack, but simply rubs over time. I would love to leather wrap mine.
I too have some firebird door panels. Have you seen a write-up on how to convert from camaro panels or are you just wingin' it?
Old 11-11-2007, 05:03 PM
TAEnvy's Avatar
Havent seen them, I figured they just fit, If not Ill have to find some write ups, no biggie really.
Old 11-11-2007, 05:54 PM
01ssreda4's Avatar
i will tell you some secrets from someone who has done lots of interiors. SEM paint is the best for plastic interior pieces. its expensive but it works great, i buy mine from the auto paint store, and they have every shade imaginable. also duplicolor has a vinyl and fabric dye that works great. i had a beater TPI iroc and i shot the entire door panel, plastic, carpet, and vinyl and i couldn't believe how good it looked. 6 dollars at pep boys or auto zone. btw, you cannot use the dye on floormats bc your feet will eventually stomp the color out, i did do the entire seats in my iroc and they held up very good, it is extremely flexible. anyone need seats sewed? pm me, i do them on the weekends at my house.
Old 11-11-2007, 06:18 PM
7 Second Club
Phil99vette's Avatar
Are you using any type of adhesion promoter?
Old 11-11-2007, 06:30 PM
01ssreda4's Avatar
i never use anything else, occasionally some parts will need to sanded or rubbed with alcohol, but only if they have armor all or skin oil on them.
Old 11-11-2007, 07:07 PM
TAEnvy's Avatar
okay thanks for the help with the dye.
I didnt use any adhesion promoter as per the instructions for the fusion. Im gonna let it cure for a few days and then test the durability and then heat it up and do the same then get it really cold. If I get and flakes or cracks, Ill strip it and go back from the start.
I think it will be okay though, I was really surprised with the adhesion I was getting.
I was using some Mr Clean stuff I found to clean them and I was really surprised at how well it stripped them.
But we will see.
And The carpet is going to be replaced with a true black carpet or MAYBE a stock one dyed, but after hearing that if I go the dyed route I will just buy ebony or aftermarket black floor mats
Old 11-11-2007, 09:07 PM
JustAnother95's Avatar
that looks pretty good, I've been thinking about changing my tan interior too, never really thought of painting it though, nice job
Old 11-12-2007, 07:41 AM
TAEnvy's Avatar
Okay guys what should I do with the center conole.
I dont use the cup holder or the ash stray so what sould I use to fill it in?
Im goiing with a redline shifter boot in black with white or silver stiching and im doing the same with the console lid.
Old 11-12-2007, 10:18 AM
SPECIALIZED STAINLESS's Avatar
Use fiber glass to cover them, then bondo and sand till smooth.
Old 11-12-2007, 10:33 AM
TAEnvy's Avatar
Okay. Ill look into fiberglass working, im familiar with it but never done it myself.
Hey Toofastz, I'm eagerly awaiting your leather kit. Thats what I will be doing my dash with.
Will you have it different shades, I will be looking for a true black.
Old 11-12-2007, 07:39 PM
01ssreda4's Avatar
if your fusion turns out to not be so good try the SEM. that duplicolor carpet dye is awesome, try it on a test piece and guage for yourself. the ash tray area would be bad for a hand held gps fiberglassed in and wired up. btw, if you got some vinyl, you could send me the console lid and i can sew it for you and ship it back. put like a two tone to match the shifter boot.
Old 11-12-2007, 09:07 PM
The leather kit's ready: http://store.specializedstainless.co...ry=Leather+Kit
The kit now is Ebony. The only other color I might offer is tan/beige... You can also order a free sample if you'd like.
Old 11-13-2007, 12:10 AM
TAEnvy's Avatar
Hey too fast I thought the whole dash was gonna be wrapped, I guess Ill have to tackle that by myslef.
I may be ordering some of the dash bezel pieces from you, I have yet to decide on what to do with the dash, but we will see.
Old 11-13-2007, 09:21 AM
Copy & Paste Moderator
VIP1's Avatar
Here is a write-up on how to disassemble the door panels (and change the cloth/leather if you want):
http://www.lastofthebreed.com/Instal.../DoorPanel.htm
Here is a post I made when I changed my cloth from black to silver:
https://ls1tech.com/forums/showpost....3&postcount=15
(I deviated from the LastOfTheBreed write-up a bit.)
Quick Reply: Painting Interior (Pics inside 56K welcome)
