HID Question
HID Question
Hey all. I am looking at converting my stock headlights to HID. I have been doing research for my DD as well (04 Ram). I will be ordering from LEDgauges, but have heard that the HID conversions have problems with "strobing." Anyone experience this? Also, how hard was the install? Worth it?
Thanks,
Chris
Thanks,
Chris
Thanks,
Chris
Thanks,
Chris
Copy & Paste Moderator
The problem with putting HID capsules into Halogen Reflector housings is glare. The Halogen housings can't properly focus and aim the light. Therefore the light gets sent out in a scattered beam.
strobing has not happened to me but to a couple of my friends and it was a bad ballast. one of my ballast went out completely on my car but the guy has a year warrenty and covered everything it was a non sponser.
Thanks a lot guys. The Ram has a lot more problems doing the conversion,
and I wanted to make sure it was easier on my Camaro. I will be adjusting them good,
as I get annoyed by some with them in traffic, and don't want to be that guy.
Also, do you all have the hi and low beams? Or just the lows? I never use my
hi-beams, so figured it'd be a little cheaper to go that route.
(The Camaro has two seperate bulbs for the hi/low correct? Sorry for the newb question, I'm still learning haha)
italicizedsponge, what color temp is that? Is it as blue as it looks in the picture?
Thanks again,
Chris
Thanks again,
Chris
Last edited by redss454; 11-18-2007 at 09:32 AM. Reason: Trying to make it easier to read
Thanks again,
Chris
Thanks again,
Chris
You can't quickly flash HID. You wouldn't be able to flash your High Beam anymore to signal other drivers.
The K number is the color temp. It is not the brightness (well not directly, I'll explain). 4000K - 5000K is the brightest. Continuing up the color scale, the light gets bluer then purpler and the lumens output (the actual measurement of light) decreases. In other words, a 10000K HID kit is dimmer than a 4300K HID kit. Our eyes are least sensitive to blue light. Blue light also scatters more easily. In the end, we can see better with a 4300K HID kit for many reasons.
yea i know they arent as bright as 4300K but damn they light up the road and i like the blue so thats why i got them. i saw 30000K the other day just ugly they arent any brighter than stock IMO and are a deep purple
