Detailing My Black Car?
first im probably going to clean with
1. Dish washing soap to strip the wax from my car.
2. dry car
3. spray lubricant or apply car washing soap with a mit and apply small sections at a time to use the clay bar.
4.rewash car.
5. Finally use mother's or meguirs 3 step system.
Did I cover everything for a descent detail? Im applying all my hand. How long will this take?
2. dry car
4.rewash car.
2. dry car
4.rewash car.
2. dry car
4.rewash car.
I will have to disagree with Eddie. I am a member of Meguiars and we highly recommend using the dishwashing detergent. It strips all of the old wax and whatever else on the paint off. Claying the whold car is up to you. I usually clay the whole damn thing. I quicker route is to wash the car, make sure the section still has soap on it and use that soap as a lubricant to clay. You kill two birds with on stone. Which Meguairs products are you using?
USE dawn dish detergent to wash the car prior to claying the car and after you clay it. The Dawn will strip off the wax and then completely clean the residue and contaminates from claying the paint.
I am going to use the three step system but I havent look into it that much yet. Can you help me out on picking the right detailing products from autozone or any other autoshop. Also show the steps used to have a great exterior detail. PLEASE!
You cant do the step process with Autozone stuff. You have to use Meguiars professional line. You can order from Meguairs.com. If the car is really beaten up, start with the #83. Go to the #82 after that. Then do the NXT for protection. All in all, it is a 5 step process in which is decribed on meguiars.com. In the Vette, I started with the #82 and then the NXT. You dont have to start with the harsh product first. Do the light stuff and see if you get the results that you are looking for.
Why are you guys using Dawn? If you're going to polish your vehicle, the wax will be stripped away anyway. Yes, Dawn will strip wax and contaminants...but there are much products out there for you to use which are MUCH easier on your paint.
I personally always use a pre-polish cleaner after a good wash (with my regular car soap) and then I clay bar the entire vehicle. The pre-polish cleaner not only will take all of the contaminants out of the paint but it will also leave your paint with a clean, smooth and slick surface. Dawn can never do that.
My process is as listed below:
Wash with regular car soap
Clay entire vehicle
Pre-polish paint cleaner
Polish with a medium pad for a regular maintained/swirl job
Apply carnauba wax for shine or a heavier duty wax for a daily driver
My favorite combo for black is as follows in a detailed process/list of products:
Wash with Sheep Skin Mitt & Optimum Car Wash
Clay with Four Star Detailing Clay using .5 oz Optimum Car Wash to a 16 oz spray bottle of water for lube
Wash with Sheep Skin Mitt & Optimum Car Wash to remove residual clay from car
Moderate swirl removal -
Menzerna SIP or IP with a Orange med. aggressive or White polishing pad. The pad needed will depend on the severity of the swirls - do a test spot to determine which pad will be needed. Use Porter Cable 7224 buffer on speed 5.5
Finishing/light swirl removal -
On black, the best finishing polish in my opinion is Menzerna finishing polish (FPII) - nothing I've used finishes down as well as Menzerna. Use Porter Cable 7224 buffer on speed 5.5 and a white polishing pad
Protection -
I always use a good carnauba on black such as Pinnacle Souveran Carnauba Wax or P21S Concourse-Look Carnauba Paste Wax. It may not last as long as a sealant, but it gives the paint a nice deep, rich glow. Since black paint shows every imperfection, a carnauba wax will also help cover slight imperfects - unlike a sealant that can highlight them.Use Porter Cable 7224 buffer on speed 2.0 with blue/black wax applicator pad.
It's a complicated process but in the end, it's always worth it. You have a black car. It's by far the most kick *** color when cleaned correctly. Treat it as such.
Clay entire vehicle
Protection -
-Mike
Thanks for the help. I think im going to wash the car with regular soap and then clay the car. Later put a pre-polish on it. The car isnt that filthy, just want to do it because I want to get the swirl marks out. Will I be able to get most of the swirl marks out with my hand?
Dawn is used as an eraser of any old wax.
It's used to get rid of all the crap and get down to the clear coat so that what ever it is your applying can be applied to a clean smooth surface. Dawn should be used as a one time deal to start over. Zaino ( awesome stuff ) recommends this in their application process.
Zaino's awesome!
Zaino's awesome!
