Sponsored by: DashLynx
Help needed with Detail
Old 03-24-2008, 11:30 PM
fbodyman1026's Avatar
Default Help needed with Detail
so i was washing my t/a that i bought recently this winter and noticed that on the bottom of the drivers side skirt there is yellow paint spattered all over. The previous owner must have ran over a wet painted street line. So i was wondering what would be the best way to get the yellow paint off the bottom of the side skirt. It's on there pretty good but i could chip a little off with my fingernail.
thanks guys.
-steve
Old 03-24-2008, 11:40 PM
Customizing Director
MadIceV8's Avatar
A Clay bar should be able to take care of that without a problem. You'll have to wax the car afterwards as the clay bar will take everything off.
Old 03-25-2008, 10:51 AM
alright ive never used a clay bar before. what exactly is it?
Old 03-25-2008, 01:38 PM
QWIK Z of OP's Avatar
if clay bar doesnt work, which it should...there are a lot of products you can find at an auto store that will take it off. i use this stuff called xenit but i get it from work so i dont know if it's sold in stores or not.
Old 03-25-2008, 02:26 PM
95TAGary's Avatar
You'll find a clay bar with the detailing supplies in Autozone, Wal-mart etc..
the clay bar will take all containments off the vehicle for a very clean feel and take off what you can't see before you wax. It'll also take previous wax off the car. Make sure you follow directions and keep the car wet when you use the bar. Also if you drop it throw it away because you'll get tiny rocks or particles on the bar that might scratch the car. Will make the car look 100% better before waxing it.
Old 03-25-2008, 04:43 PM
The Guz's Avatar
Just like everyone has said try the claybar. You can also try some rubbing compound.
Old 03-25-2008, 05:59 PM
thanks guys, i was gunna just do a wash/wax but now im going to use a clay bar before
Old 03-25-2008, 07:42 PM
TARaptor's Avatar
if the chunks are big clay bar-ing them off will be a pain. I worked at a dealership and we used a paint safe body prep solvent to get that stuff off, the best way I found to get the road paint off was to soak a rag with the solvent and hold it again the paint for about a minute and they would come off really easily. Then rinse and wax area. Someone will probably say its not a good idea but I did it several times with no ill effects. Just my experience.
