Flares going into third gear
Old 10-30-2008, 04:35 PM
Alvin's Avatar
Default Flares going into third gear
We got a trans built by a great tranny company.. Used a couple of them and haven't had any problems until this one. I will say that I haven't been able to get a hold of them to ask them thier take on it because we always seem to be calling after thier hours but I thought I would ask here just to get a professional opinion from one of the tranny companies.
This car is a twin turbo charged F body. It makes about 550 at the wheel and has a vigilante 3600 built for the turbo. The stall feels marginally too loose but precision did it for the turbo and power level.
The car goes into second and fourth just fine but in third shes got a heavy flare right after the trans commands third gear. It literally feels like the drive shaft has broken and it flings up in the rpm. It will go from 6000-6100 to 6850 instantly... and even faster than our datalogger can see the RPM between.
Old 10-30-2008, 04:47 PM
LS1Tech Sponsor
performabuilt's Avatar
Sounds like the band is being released prematurely during the 3-4 clutch application, Is this only at WOT or do you feel the flare at all times ?
And when it does make it to third is the shift firm?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 10-30-2008, 04:52 PM
Alvin's Avatar
I can't stay in it long enough to let it get to third gear. This is only under wide open throttle
It literally rings up like it had a broken driveshaft or something.
One thing I just thought of.. I put a aux cooler with -6 AN line in the fender well (passenger) so I would expect another 2-3 foot of line for it to go thru. Thats nothing that would hurt the line pressure or anything is it? I had to do it because with all the turbo stuff theres no room under the hood or before the intercooler/radiator
Old 10-30-2008, 05:00 PM
LS1Tech Sponsor
No that would have no affect as far as the lines go.
I would have to guess that either there is some hydraulic leak in the 3-4 clutch circuit or a feed hole in the valve body has been drilled incorrectly allowing the release of the 2-4 band early.
I really cant think of any other possibilities and certainly no electronic possibilities
__________________
Call 888-744-6542
Old 10-30-2008, 05:16 PM
dlove's Avatar
I have been tuning on a car that does the same thing. Now regards he has a stock trans, and I just suspect that the tranny is going out.
Old 10-30-2008, 05:26 PM
LS1Tech Sponsor
That is possible since a similar affect might be had by excessive 3-4 clutch clearance
__________________
Call 888-744-6542
Old 10-30-2008, 05:33 PM
dlove's Avatar
thats what I figured it was. Shift times are set low, while pressures are stock. Flares from 6300 to 6700 and then hangs for a sec and then goes into the shift extension.
Old 10-31-2008, 08:49 PM
Alvin's Avatar
Talk to the trans builder. They said that it was either tune, its been over heated, or its low on fluid.
I've been tuning GM's for 7-8 years now, even restarted on the tune just to double check. The fluid is fine.. We've checked it over and over. The temp hasn't been over 200 and usually sits around 180.
We put a mechanical gauge on it tonight and will try it tomorrow. With it going into every gear at wide open other than third fine I believe we are going to find that something is wrong with the trans.
Old 11-02-2008, 06:05 PM
BJSS25's Avatar
That sucks Alvin, but I am sure they will make it right.
Old 11-02-2008, 06:43 PM
LS1Tech Sponsor
Post what you see but IMO a flare on the 2-3 at WOT is more likely a mechanical issue than a tuning issue .
__________________
Call 888-744-6542
