P1870 transmission slipping code. converter won't lock.
So I got three codes. I've posted this before cuz my 02 sensor got wet, but now i am pretty sure that sensor is bad.
I got these:
p0135
p0155
p1870
are the 135 and 155 both the driver side o2? i forget
The transmission just won't lock, this happened after normal driving. Was working fine and i got some gas and got back on the highway and it simply won't lock. I was simply wondering if a bad o2 can cause this issue?
I got these:
p0135
p0155
p1870
P1870 do a google search very common on the 4L60E, there is a fix that has to do with replacing the valve body. I think one of the piston bores gets worn allowing fluid to leak past, not positive. I replaced one on my suburban, you can buy rebuilt valve bodies on ebay. Not hard to replace just make sure to get the screws in the right place or the long screws could crack the case.
LS1Tech Sponsor
PO1870 Happens when the converter is commanded to lock and does not, So no the O2 sensors are not the issue if they through missfire or something were preventing lockup the command would never be given,
You problem is going to be TCC SOLENOID, PWM SOLENOID, WORN VALVE BODY, BAD TCC ORING ON INPUT SHAFT, BAD CONVERTER CLUTCH.
__________________
from doing search after search...the valve body is probably it.
too bad no one ever posts up if they fix the problem...gonna do some more searching
thanks performabuilt
one more question...this doesn't necessariliy mean the transmission is on it's last leg does it?
unfortunately i just don't know too much about my car, especially the transmission. i'll have to ask a friend to help me and if he can't, i'm not so sure i can't keep buying new stuff for my car cuz i honestly just dont know how everything works and i don't feel like i know what i am doing...sure i could pay someone to do it but whats the fun in that...
wish my dad knew more about cars
