M6 to A4 swap
Old 04-03-2009, 10:25 AM
BlackTA96's Avatar
Default M6 to A4 swap
I've got a buddy whos planing on putting a 4l80e in his TA. Right now its a t-56. What gotta be done computer and wiring harness wise to run the trans?
Old 04-03-2009, 10:29 AM
Gingervitis Addict
slow67's Avatar
By an M6 to 4L80E conversion wiring kit. Either swap segments with EFILive, or have HPTuners do it for you (you can't do it yourself with HPT). Or a tuner can do the above. I have HPTuners, and bought the harness conversion from LSxTune.com
Old 04-03-2009, 10:33 AM
BlackTA96's Avatar
sweet ****!!
Old 04-03-2009, 10:42 AM
Gingervitis Addict
slow67's Avatar
Originally Posted by BlackTA96
sweet ****!!
Yeah, IMO the wiring was the easiest part of the swap!! (~30 minutes at most). the hardest part was stabbing the 4L80E by myself. I did the ENTIRE thing with ZERO help from anyone.
Old 04-03-2009, 11:11 AM
BlackTA96's Avatar
i noticed on that harness that its bare wires at the end. do you have to splice those in somewhere? or whats the deal?
Old 04-03-2009, 12:43 PM
Gingervitis Addict
slow67's Avatar
Mine had pins on the end that go into the PCM. You pull the connector apart and put them in. It had 1 bare wire, and that was +12V for the solenoids/switches in the transmission.
Old 04-03-2009, 01:00 PM
BlackTA96's Avatar
Oh...
maybe i was just looking at it wrong...
Old 04-03-2009, 01:04 PM
ssick1's Avatar
around how much will all this cost to do the swap they are selling me a 4l60e tranny with autoshifter for 850?? is that a good deal
Old 04-03-2009, 02:45 PM
MY99TAWS6's Avatar
You need more than just a harness and trans for an m6 swap.
Here is my list
You need a 4l80e crossmember with torque arm relocation as the 4l80e don't have any provision to mount torque arm on it. I got mine from bmr. You can go with body mounted torque arm as well.
I got flexplate from speed inc wanted sfi one.
I got torque converter from yank for the 4l80e think 4l60 ones are different and dont think they work with 4l80e.
I am going to use hptuners for operation didn't want manual operation.
I will be buying harness from lsx mentioned above.
You need of course auto top piece for console unless think you use b and m shifter ,think it works on stock manual console. I am going to stock shifter . You could get auto pedals I think will use manual ones for temp.
I got lokar fender mounted dipstick.
And tranny cooler is good idea.
Course you can save some bucks and run stock 4l80e stall.
Old 04-04-2009, 11:08 PM
js2fst's Avatar
What about the tci
