TH400 tranny shield
TH400 tranny shield
I am putting my 2002 trans am convert. back together and i am expecting some serious hp out of the 451 lsx with a F1C procharger. I am really thing of putting a cover / blanket over the trans. What would you use? Also what name brand is a good one? Has anyone used them on a trans am without having to modify anything?
Are you worried about the converter area or the guts of the trans? If its the former, just stick an ultrabell on it. If its the latter, you shouldn't have a problem with the guts flying out unless the trans is downshifted at high RPM.
LS1Tech Sponsor
If you have ever seen a th400 direct drum blow up you would run a blanket or sheild!!!
I have seen it. NOT GOOD
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
